bluetooth?? :uh:
Old Mar 13, 2009 | 03:54 PM
V8RdnLow's Avatar
V8RdnLow
Wish I had that in my car
Old Mar 13, 2009 | 04:01 PM
john_papa's Avatar
john_papa
hahahaha. i wish i could get it to work
Old Mar 13, 2009 | 09:47 PM
sleeper408's Avatar
sleeper408
Originally Posted by john_papa
ok i just opened it and google the number. and nothing. and the hole that its in looks oem. its like a perfect place for it??? damn im confuse. could this be oem? its a 98 gs300
I'm pretty sure they didn't have Bluetooth technology back in '98.
Old Mar 14, 2009 | 11:21 AM
augdogg's Avatar
augdogg
Someone please find it! Thats a real clean setup...
Old Mar 14, 2009 | 11:25 AM
mtparker18's Avatar
mtparker18
Forreal. its badasss!
Old Mar 14, 2009 | 12:51 PM
john_papa's Avatar
john_papa
yes please help i really wanna make it work
Old Mar 15, 2009 | 11:41 AM
Kansas's Avatar
Kansas
Geez guys, this is just one of the components for the one of the old dealer installed Lexus phone systems. You don't have a handset or a charging cradle in the console? There were two handsets available for the 1998 model year -- a wireless handset and an old style fixed phone.
If there is no handset cradle in the console, then a previous owner must have removed it. The little microphone on the headliner has me confused. The microphone for the Lexus phone system was in the control module attached to the steering wheel.
The cool thing about the gen 2 GS up to 2000 is that some of the phone prewiring can be easily used for an aftermarket Bluetooth kit. Somewhere under the console of your 98 GS there should be a six pin phone connector with the middle front pin being an audio system mute. Plugging an aftermarket Bluetooth kit's mute wire into the middle front pin makes the radio mute automatically when a phone call is in progress.
You might want to remove the components for the old Lexus phone system or at least disconnect them -- they are worthless since the old phone system was analog. You don't have to remove the control unit from the steering wheel -- you can leave it place unless you want to remove it and buy the little plastic blank to cover the hole.
Check the trunk for a phone ECU and, if there, unplug the connectors. If there are two big connectors that plug together, then do it to complete the circuit. I've only worked with this stuff in the LS -- the phone ECU could be under the back seat in a GS.
I use the under-console mute pin with the aftermarket phone kit in my 00 LS400. My 00 LS also has a phone antenna imprinted on the inside of the rear window which I use to boost the signal on my GSM phone ... don't know if would work with Verizon's CDMA, etc. Your GS may also have an imprinted phone antenna ... if so, there is a coax cable under the center console for it if you wanted to use a charging cradle with the rear window antenna for a modern phone.
The same phone charging bases with interchangeable cradles sold by Lexus dealers in the U.K. and Europe are available pretty cheap on eBay -- search for "Bury" in the phone section of eBay. Bury is the European company that makes this stuff for Lexus and Toyota.
Old Mar 21, 2009 | 10:32 PM
R.DUB's Avatar
R.DUB
Not OEM on a 98. Looks like a high quality aftermarket item. Are you sure it's bluetooth? Good luck and please advise us of your findings.
Old Mar 24, 2009 | 08:49 AM
Kansas's Avatar
Kansas
Nope, it is still a part of one of the two optional Lexus analog phone systems that were available on the GS in 1998. My 2000 LS400 has a similar phone control module on its steering wheel -- see attached pic. A friend's 99 LS400 has the same phone control module on his steering wheel and his LS still has one of the old fixed handsets in the upper console tray. Most people remove the Lexus phone cradles and handsets to free up console space ... and because they no longer work.
The Lexus steering wheel phone control module looked about the same for all model years from 1990 through at least 2000. If I remember correctly the Lexus phone option was over $1,000 in 1990 when I bought my first LS400. At the time, the Lexus dealer also offered a President brand phone through Southwestern Bell for $100 that looked almost identical to the Lexus phone but did not have the steering wheel command module -- I bought it and used it for almost 10 years.
Lexus offered a bunch of different phone systems during the 14 model years they offered them. The last model year a phone system was offered in the GS was 2003: http://www.lexus.com/cpo/model_library/GS/2003.html
I think 2003 was the last year a Lexus phone system was offered in any Lexus as an official option.
Attached Thumbnails bluetooth?? :uh:-imgp2411.jpg
Old Mar 24, 2009 | 12:21 PM
sleeper408's Avatar
sleeper408
Looks like you need to turn it into a bluetooth module or remove it completely. GL!
Old Mar 24, 2009 | 12:41 PM
esolo98's Avatar
esolo98
Kansas is correct, my 98 came with one too. I also got the phone, with Lexus written on it.
But I took all of it out and got the bluetooth with the Pioneer AVIC-D3.
Old Mar 24, 2009 | 12:50 PM
GSquicksilver's Avatar
GSquicksilver
LOL, yes kansas is correct. it's part of the old carphone option that used to be available with our cars, haha
Old Mar 25, 2009 | 12:17 AM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
I dont know anyone who can compete with Jim (Kansas) when it comes to Lexus factory phones.
F250
RX - 3rd Gen (2010-2015)
19
Oct 15, 2019 09:35 PM
ronsmoove
Sep 13, 2015 06:19 PM
Mitty
May 25, 2014 04:21 AM
dfw350
Jul 12, 2006 09:46 PM
