Steering Wheel
Old Nov 4, 2008 | 12:17 PM
OnyxGS300's Avatar
OnyxGS300
Default Steering Wheel
Does anyone know if its a way to stop the steering wheel from moving in and out when you start and cut off the car? I think that the motor maybe starting to go out a little on mine.
Old Nov 4, 2008 | 12:20 PM
scottgs's Avatar
scottgs
Pull the fuse on it?? Not sure. LOL
https://www.clublexus.com/forums/sho...ing+wheel+tilt
Old Nov 4, 2008 | 12:21 PM
FlavesLex's Avatar
FlavesLex
Go to the dealer and have the feature removed. If you need more info, the search feature is a great help
Old Nov 4, 2008 | 01:27 PM
gsrell's Avatar
gsrell
I'm with you on that!! This morning, it was cold out and my wheel would not move either. Only out and not down. After a short drive then getting back in the car hours later, back to normal. SCAREY!! I may have the feature pulled as well. There were prior posts about lubricating, which could help and/or prevent, but is impossible.
Good luck.
Old Nov 4, 2008 | 01:35 PM
eyecon7's Avatar
eyecon7
The LS's used to have an on and Off switch.. dont no why they didnt put those on the GS...
Old Nov 5, 2008 | 02:06 PM
dxb_8788's Avatar
dxb_8788
i want to disconect mine too one day the motor will say enough and die
Old Nov 5, 2008 | 07:10 PM
GS_OREO's Avatar
GS_OREO
I just set my desired position of the steering wheel.
Removed the lower steering column cover.
And disconnected both both motors for the tilt, telescoping feature.
Old Nov 5, 2008 | 10:42 PM
CK6Speed's Avatar
CK6Speed
Only the early LS had the on off switch. Not sure when the changed occurred, but by the time I got my 99 LS it had no on off switch.
Old Nov 6, 2008 | 12:06 AM
[ant]'s Avatar
[ant]
the 1st Gen GS also had the on/off switch beside the toggle switch on the majority of models. (some didnt but not sure why because we didnt notice a consistency of year model or specification level!)
jorgie523
Sep 2, 2015 09:08 AM
EJ255t
Jul 10, 2015 04:16 PM
pvt9471
Jan 2, 2012 02:44 PM
250aznboi
Jul 29, 2010 02:13 PM
