Window Help
Old Oct 26, 2008 | 05:00 AM
GSTYLIN's Avatar
GSTYLIN
Default Window Help
Hey all....
Okay this is what happens with my rear passenger window.
If i roll it up with the auto click either from the main switch or the switch from the rear passenger seat, the window goes up closes and than automatically goes down again.
Unless I close it without the auto click it will not close. Keeps rolling back down.
Any ideas would be great cause it's aggravating.....
Old Oct 26, 2008 | 05:59 AM
Mr Jokster's Avatar
Mr Jokster
close all the windows with your key in the door! ALL THE WAY! I had the same problem. I had left them open half way (with key) then tried to close them with the door switch, and it did the same thing... try that?
Old Oct 26, 2008 | 11:24 PM
quyzie's Avatar
quyzie
i have the same issue.. closing the window all the way with the key in the door does not work. it still does the same thing.
Old Oct 27, 2008 | 07:45 AM
Infamous 1's Avatar
Infamous 1
Do a search for how to resetting the window regulator.
Old Oct 27, 2008 | 08:27 AM
JoelGs's Avatar
JoelGs
Seem like..This is common for the GS. I had issue with my front passenger window. When I close with the main switch(Driver) and it goes down instead. I had to role it all the way down and it doesn't respond at all..for at least 15 minutes then I can make it goes up. Does anyone had any ideas how to fix this prob. HELP!!!
Old Oct 27, 2008 | 10:50 AM
Infamous 1's Avatar
Infamous 1
Here is a link to resetting the window regulator. See if this helps.
https://www.clublexus.com/forums/sho...+window+switch
Old Oct 27, 2008 | 02:21 PM
JoelGs's Avatar
JoelGs
Thanks...Infamous1, I'll give it a shot later to see if that will help solve this mystery...
TrymyIS
Jan 28, 2021 05:13 PM
mbogo
Oct 15, 2014 04:48 PM
alselby
Sep 21, 2008 11:41 AM
SloGS3
Jul 27, 2006 12:57 PM
tofu_house
May 28, 2005 01:55 PM
