Ignition Upgrade
I have searched and wasn't able to find much...
Has anyone with little to no engine mods done an ignition upgrade? If so, which company, was the install hard, price, was/is it worth it, did you notice any difference is performance or gas mileage?
Thanks for your input!
Ignition as in a higher voltage spark or ignition timing?
Also, why would you do this without other more simple, more efficient mods
Does not make sense to do this mod and is probably the reason no one has replyed to you post.
Stay off the gas pedal or buy a hybrid
Keeping up with all maintenance and proper tire pressure is the best way to get optimal fuel consumption on any vehicle. Don't waste any money on anything that says it will increase MPG, most likely it won't happend.
Okada Project makes some ignition upgrades for the GS300. You can check them out.
http://www.okadaprojects.com/usa/applications.htm
You will not gain anything by creating a bigger spark, that is mainly used on boosted vehicles. I don't know where you got the idea about an ignition upgrade can give you better MPG, but it's not true. Our ignition system is already a good one in stock form. Like I mention before keep up with your maintenance and tires pressure, aligment, etc...
it seemed like the post was there a lot longer, oh well.
Are you suggesting for him to run leaner
There is no other way he can get better MPG than stock settings. All cars are detuned for emission and fuel economy
not to mention most tuners will set A/F controllers to run at WOT. This is the worse fuel saving tip I have ever heard Let me get this straight, fuel controller and intake
not to mention most tuners will set A/F controllers to run at WOT. This is the worse fuel saving tip I have ever heard though it isnt completely his fault, a lot of the ads on tv have misinformed saying that an aftermarket intake reduces restriction and improves mileage.
the point of an intake is to get more, cooler and more dense air into the engine to get more fuel into the engine.
adding an intake and tuning to use less fuel (i.e. lean) using an A/F controller not only cancels out any power gain you would normally see and also poses potential problems for the engine later on down the road.
RX3302004
Sep 11, 2013 09:59 PM
juice14
Performance
Jul 4, 2008 08:57 AM
