Misfiring, HELP NEEDED.
Old Sep 27, 2008 | 11:54 AM
MR2-Mike's Avatar
MR2-Mike
Default Misfiring, HELP NEEDED.
Hey everyone,
I got the check engine light and VSC off lights. So I went to autozone, got a quick read and it said misfire No. 2 cylinder.
Long story short, I replaced the wires, plugs, and the coil that goes to the no. 2 cylinder and my car is still trembling and the lights are still on.
Also the throttle control motor seems to be knocking pretty loudly if your up under the hood, if this helps any.
Any help is appreciated,
Mike
Old Sep 27, 2008 | 01:46 PM
Debonair's Avatar
Debonair
Did they clear the code and it came back on or did they never turn it off? Also what was the actual code # (P####)?
Old Sep 27, 2008 | 03:32 PM
MR2-Mike's Avatar
MR2-Mike
i did it myself..and i cleared the code by battery reset...still came back. the code is p0302.
Old Sep 27, 2008 | 08:43 PM
VAgs430's Avatar
VAgs430
clean you MAF sensor... i had simmilar problem with misfire and sluggish acceleration and a simmilar CEL but different cylendar... took it to a mechanic and he cleaned my MAF sensor and car felt like a world of a difference.... its easy to do jus look it up through the search tool... u can pick up air intake/throttle body cleaner from and parts shop or even MAF sensor cleaner if your lucky..
Old Sep 30, 2008 | 07:56 AM
BossGS4's Avatar
BossGS4
I've also read that a sticky injector can cause misfiring as the jet does not close when it is supposed to.
DaveC
Gioperrone
RX - 1st Gen (1999-2003)
16
Mar 7, 2021 06:29 PM
bigrobbyt
Feb 26, 2013 08:19 PM
1lexus2c
Jun 4, 2011 10:10 PM
Philly RX
Dec 20, 2007 03:07 PM
#1gs300
Jul 9, 2006 07:16 PM
