bulbs in the climate control unit going out
Old 06-15-08, 08:56 AM
gsCrazy
gsCrazy's Avatar
Default bulbs in the climate control unit going out
most of the bulbs in my climate control unit has gone out and the words on my buttons do not light up. does anyone know if lexus sells the screw type bulbs with the green sleeves? if not does anyone know the specs of the bulbs so that i can see if they have them at radio shack?
i'm going change all of them at once seeing how it's such a pain to take the unit out.
Old 06-15-08, 09:26 AM
dave11428
dave11428's Avatar
You probably gonna have to open up the unit and test the voltage of the bulb and buy close replacements as I don't believe you will be able to find the exact bulb. Let us know if u do find the exact bulb.
Old 06-15-08, 09:43 AM
Lyrical
Lyrical's Avatar
i'm in the same boat....they just started going out after 9 years
Old 06-15-08, 01:20 PM
gsCrazy
gsCrazy's Avatar
i will definitely let you guys know but how do i test for the voltage of the bulb??
also, after a bit of searching online, i found that those bulbs are the "neo wedge" type bulbs. i don't know if they're type A or B though.
also, i just opened up my climate control unit again and on the base of the bulbs there's an "H" letter and also a number. I see numbers 4, 5 and 6. does anyone know what the number designates?
Old 06-15-08, 02:39 PM
phillygs3
phillygs3's Avatar
This happened to my friends ES he purchased replacement bulbs from the stealership for like 3 dollars apiece probably gonna need like 8 of them while you got that badboy open should just replace all of them
Old 06-15-08, 09:52 PM
pitmanr200
pitmanr200's Avatar
get them from sewell lexus. I just got the hole set which is 8 bulbs for around 30 bucks shipped. If you need part #'s pm me and i will give them to you.
Old 06-15-08, 10:24 PM
dung0981
dung0981's Avatar
Convert to LED bulbs, better looking, and last longer
Old 06-16-08, 04:52 PM
SoloKaMGS
SoloKaMGS's Avatar
do you have a diy for this dung"?
Old 06-16-08, 04:59 PM
dung0981
dung0981's Avatar
sorry, i don't. I did it long time ago. still work great, i love it every min
Basically, take out the OEM bulbs and solder the resistor in series with the LED. I don't remember exactly the value of the resistor, its around 560-680 ohm should be good enough
Kramer
SC- 1st Gen (1992-2000)
05-14-09 10:42 AM
gsfor
03-07-05 09:06 AM
Ryan
72
02-24-04 01:49 PM
adidosc
Lighting
05-23-03 04:46 PM
mjr24
12
11-06-02 07:34 PM
Quick Reply: bulbs in the climate control unit going out
