Camber issue? Thoughts Needed!
Old Jun 2, 2008 | 12:06 AM
VNN326's Avatar
VNN326
Default Camber issue? Thoughts Needed!
i installed 20mm H&R Spacers today with the studs. when i finished installing them i knew one side is more pushed out the the other. is this a camber issue because i never got my camber redone when i put on my new stocks+springs.
Old Jun 2, 2008 | 10:16 AM
Kyle Harty's Avatar
Kyle Harty
I've seen alot of cars that seem to have slightly different clearance on each side, you'd never notice unless you're running an aggressive wheel setup. It could very well be normal and there wouldn't be anything you can really do about it. That being said, if you haven't had an alignment since you lowered the car (not sure if that's what you meant), you should do that before you chew up an expensive set of tires.
Old Jun 2, 2008 | 11:53 AM
LS_FosHO's Avatar
LS_FosHO
hopefully you can correct this by camber adjustment..
any pics?
Old Jun 2, 2008 | 01:00 PM
4ntvings's Avatar
4ntvings
wait, you installed spacers and now 1 side/set of wheels is pushed out farther than the opposite side?
or do you mean 1 side cambers more than the other?
either way, you still need to get an alignment done, since you havent done so yet.
TrueDat96
Mar 31, 2016 11:46 PM
LEXisJaDeM
Suspension and Brakes
22
May 6, 2009 09:36 AM
gs350on22s
Mar 24, 2009 05:48 PM
newyorksc
Apr 19, 2005 08:27 AM
One HoT
Nov 7, 2002 02:20 AM
