How to replace bulbs on Tail Lights
Old May 27, 2008 | 02:47 PM
ted920's Avatar
ted920
Default How to replace bulbs on Tail Lights
Can;t find any info on how to replace bulbs on the tail lights on the GS. The bottom light on 1 of my tail lights is either bad or the connection is lose b/c most of the time its out but sometimes it comes on. I need to fix this and am asking for directions or DIY guide.
I found nothing on this in the owner's manual, only "Take it to the Dealer".
I know you guys have good info on this am am seeking your help.
thanks,
Ted
Old May 27, 2008 | 04:05 PM
-Future-'s Avatar
-Future-
If your talking about just replacing a regular bulb in your taillight, just pop your trunk and behind the tail lights - carpet - there should be little carpet flaps with velcro and that is what hides your bulbs.
-Future-'s Avatar
-Future-
Old May 27, 2008 | 04:54 PM
jcat_350's Avatar
jcat_350
i know in my 01 you have to pop a couple of plastic clips and then slip your trunkmat out from under the fender rail and you should see your housing right there, just locate the bulb you need to take out and either twist the boot or slip it out of the hole to get the bulb out and just reverse the process to put it all back.
Old May 27, 2008 | 05:01 PM
KYGS300's Avatar
KYGS300
Just did this the other day.
Behind your taillight (inside the trunk) you should see two plastic caps. Pop those caps out and use a socket wrench to unscrew the nuts holding the housing in place. You should be able to pull it out and replace the bulb or check how well the previous bulb is plugged in. If it still comes on occasionally, it's probably the connection or a bad wire.
Try replacing the bulb and see what happens. If that doesn't work, I'm not the person to help you
Hope that helps.
-Lex n00b
Old May 25, 2011 | 07:58 AM
handzilla's Avatar
handzilla
I have a 99 GS300. I have removed the four nuts but cannot seem to pry the housing out. Any pointers?
Old May 25, 2011 | 08:05 AM
Infamous 1's Avatar
Infamous 1
There are 2 screws and 2 nuts. The screws are located under to caps on the inner part of the taillight. They 2 nuts are behind the taillight closer to the quarter panel. Once these 4 are removed, remove the entire assembly giving you access to the bulbs.
Old May 25, 2011 | 09:14 AM
lexybaby77's Avatar
lexybaby77
I would go with this . No bolts or screws. Just open the velcro, remove the old light and put new one in.
Old May 25, 2011 | 09:22 AM
ThomasGS4's Avatar
ThomasGS4
He's talking about the bottom bulb on the outer tail lights.
Old May 25, 2011 | 09:45 AM
lexybaby77's Avatar
lexybaby77
Ooops sorry, didn't read the whole thing!
Old May 26, 2011 | 12:19 PM
handzilla's Avatar
handzilla
haha thanks guys! got it all done yesterday!
exaktoh
Mar 25, 2017 07:46 AM
kowala
Sep 23, 2014 10:48 PM
chuckli
Feb 23, 2009 10:44 AM
alexus
Oct 21, 2002 06:02 PM
Taka
Oct 7, 2002 08:04 PM
