Info on changing rear tail light that blew
Does anyone have a link to a diy on how to change one of the lights in the rear tail light for a 98 GS400
Still looking for a cheap way of getting an AC compressor
Thanks!
Thanks!
1. Open your truck and at the back of the taillight, there should be 2 plastic screw-on tabs. Remove those two
2. Use a 10mm socket to pull out those two nuts
3. Now go to the face of the tails and use a small flat-head screwdriver to take out the plastic tab located at the inner part of the tails.
4. use the 10mm socket to take those two bolts out.
5. You're free to pull the taillights out and then just remove the socket for the bulb
RA40
Jun 28, 2006 01:54 PM
