leveling lights
Old Oct 31, 2007 | 04:41 AM
RI-Lex's Avatar
RI-Lex
Default leveling lights
okay I know my GS4, has the leveling light feature, but once I park on a flat surface, i look at the level thing on the headlights and there not in the middle there a bit off, should i adjust them or just let the auto leveling do it's thing? I always leave my lights on auto
Old Oct 31, 2007 | 05:49 AM
TruPlaya26's Avatar
TruPlaya26
CL Folding 10,000
Hmmm, I've noticed the same thing on my '01 430 ... i wonder if it's not leveling properly since it's not level when it's off ... I do think that my headlights point a little too low when they turn on ...
Old Oct 31, 2007 | 07:02 PM
swollio's Avatar
swollio
how do you manually adjust it???
Old Oct 31, 2007 | 07:21 PM
Spyder78's Avatar
Spyder78
CL Folding 25,000
there is a 10mm screw on the back of the headlight. One is for height the other angle.
Old Nov 1, 2007 | 10:53 AM
nytoy's Avatar
nytoy
Actually I believe it's an 8mm, tighten it to move them upwards.
Old Nov 1, 2007 | 10:59 AM
gapxguy's Avatar
gapxguy
I had the same problem. The driver side was higher than the passenger side even though both sides level at the initial startup. I manually adjusted the said bolt behind the headlight and now both auto level perfectly.
lexman52
Apr 30, 2017 05:59 AM
Polo708
May 14, 2014 01:21 PM
firstimer
Dec 29, 2011 08:07 AM
bigcory
Dec 26, 2008 06:34 PM
tieu
Oct 8, 2008 10:41 AM
