Error Code P0121
Old Sep 4, 2007 | 12:54 PM
j.tom's Avatar
j.tom
Default Error Code P0121
What is this code really means? Cause i did a search ,Is it the TPS or the APPS???Had anyone here had this code P0121(just this one code) and had fix the issue?Please help,THANKS.
Old Sep 4, 2007 | 01:02 PM
oohpapi44's Avatar
oohpapi44
CL Folding 100,000
https://www.clublexus.com/forums/sho...ighlight=P0121
Old Sep 4, 2007 | 01:03 PM
kit cat's Avatar
kit cat
your bosses are telling you do the TPS reports
Old Sep 5, 2007 | 09:33 AM
j.tom's Avatar
j.tom
Any write-up on how to replace the TPS???Anyone here ever DIY this???THANKS.
Old Sep 6, 2007 | 10:57 AM
j.tom's Avatar
j.tom
Nobody????
Old Sep 6, 2007 | 11:30 AM
markgs4's Avatar
markgs4
the link from oohpapi44 is helpful and informative. My check engine light has been on and off for months, and I finally managed to pull the error codes last night and got this same code, so you and I are in the same boat.
When the check engine light comes on, so do the vsc and vscoff lights. The gas pedal also doesnt seem to work and I cannot accelerate the car. Does your car have these same problems? Im hoping to get this serviced soon, and hopefully it will also resolve the hard pinging issues at 1k-2k RPMs that I occassionally get.
Old Sep 6, 2007 | 12:15 PM
kit cat's Avatar
kit cat
I would try cleaning out the TB. I cleaned it and cleared out my CEL/VSC/VSC off light.
Old Sep 6, 2007 | 12:48 PM
markgs4's Avatar
markgs4
Thanks for the tip, but I am illiterate with anything related to our cars What does TB stand for??
Old Sep 6, 2007 | 05:13 PM
sleeper408's Avatar
sleeper408
Tuburculosis.... or throttle body.
I've had the same code but my car never went into limp mode again. Would a dirty MAF and TB lead to a false code? Or does my TPS or APPS need to be replaced?
Old Sep 7, 2007 | 07:13 AM
DASHOCKER's Avatar
DASHOCKER
You could have the same problem I did.. You may need the "throttle pedal" (cable) changed rather than the entire throttle body. 200 dollar part. Check this thread out. Good luck.
https://www.clublexus.com/forums/sho...ighlight=p1121
Old Sep 7, 2007 | 11:21 AM
j.tom's Avatar
j.tom
DASHOCKER,Did you replace that yourself???
Old Sep 7, 2007 | 01:49 PM
DASHOCKER's Avatar
DASHOCKER
No sir. The dealer did not charge me for the install, so I had them do it. Not an easy diy since the part (which is the throttle linkage) goes through the firewall.
Old Sep 7, 2007 | 05:15 PM
j.tom's Avatar
j.tom
Thanks everyone for responding,I will reset my ecu,and see if it (code) come back,Thanks again!!!
dadewi
GS - 1st Gen (1993-1997)
12
Oct 22, 2018 12:45 PM
jasawh
Feb 24, 2018 06:29 AM
diverchris
May 1, 2014 01:20 PM
StiCk3
Apr 26, 2008 05:40 AM
VQT
Apr 1, 2002 07:50 AM
