cooling problems
Old Aug 23, 2007 | 11:17 PM
lexoman's Avatar
lexoman
Angry cooling problems
so it was about 100 in corona ca,wife was driving on a freeway in bumper to bumper traffic when she heard a pop followed by steam from the engine,she pulled over right away and called me.when i arrived the top hose had popped off and lost most of it's coolant,connected hose and filled with water,thats all i had at the time,i drove it straight home about 5 miles watching my temp rise over where it normaly would be,before i made it home i could see steam.opened the hood and saw a large crack on the top of my radaitor.my question is what would cause the hose to pop off like that and crack my radaitor?i have ordered a radaitor.could this be caused by the radaitor cap not working correctly?car has 160500 miles,water pump,thermostat, replaced with timming belt at 140000 miles.thanks
Old Aug 24, 2007 | 02:22 AM
Bill_GS3's Avatar
Bill_GS3
CL Folding 3,000,000
A radiator cap is a likely culprit. It may not be releasing properly. There may have also been some extra air in the system. Is the new radiator coming with a cap?
Old Aug 24, 2007 | 07:24 AM
lexoman's Avatar
lexoman
i am buying a aftermarket brand so i will pick up a new cap.
Old Aug 24, 2007 | 08:57 AM
Lexmex's Avatar
Lexmex
I have seen many a time at my uncle's shop with a popped radiator cap as BillGS3 mentioned. More often the case is with a sticking or bad water pump, even though replaced not too long ago.
Also would suggest adding a bottle of Redline WaterWetter to your coolant/water mix.
Old Aug 24, 2007 | 09:07 AM
JeffTsai's Avatar
JeffTsai
Did you continue to drive the car back with leaking coolant? Usually it's not too good to do that. The motor can overheat and warp the head...and yes thats a very bad thing
Old Aug 24, 2007 | 07:11 PM
lexoman's Avatar
lexoman
i did not notice any leak up until the steam appeared'radaitor arrived today,by the way you can pick one up from ebay for $133 plus 35 for shipping made by kyco.looks like it is well built.hope there is no head damage,should have it in this weekend.
jpv7774
Oct 22, 2018 09:48 AM
thejct
GX - 1st Gen (2003-2009)
Sep 7, 2017 04:13 AM
thejct
Sep 6, 2017 10:20 AM
msc300
Jan 15, 2012 10:04 AM
VJZ
Feb 5, 2008 04:34 PM
