door caps question?
08-15-07, 02:09 PM
Picture Posting Impaired
door caps question?
does anyone know how to remove the door caps or "claddings" by chance?
08-15-07, 02:11 PM
dubsonlexus
Quote:
Originally Posted by
gotparts?
i was wondering the same thing also ??
08-15-07, 02:12 PM
i see the four nuts that you can remove, do you just use force and pull the caps off?
08-15-07, 02:14 PM
dubsonlexus
gotparts?
i know there is clips and i was told they will break when removed i know TLW removed his maybe he can chime in ??
08-16-07, 03:50 PM
08-16-07, 04:09 PM
exclusive matchup
yes, i believe you can just pull. there are double sides tape so that makes it even harder to remove.
08-16-07, 06:16 PM
Do a search and you'll find the answer. I don't have time right now, or else I would do the search for you. Chuckb posted up some pictures a while back showing exactly what the door looks like under the cladding. I believe there was a step by step instruction on how to remove them in the thread.
e
08-16-07, 07:08 PM
i searched "door cladding" and "door caps"
08-16-07, 08:37 PM
Here you go. You can ignore the stuff about replacing the rubber molding at the bottom of the door. Just check out the links posted by Chuckb:
https://www.clublexus.com/forums/sho...olding+picture
08-16-07, 08:54 PM
e-man thanks for th diy write up. this is another project that needs to be done.
LexiiBabe
SC- 1st Gen (1992-2000)
16
06-17-16 12:47 PM
adreano17
05-26-10 03:31 PM
MrMark
03-14-09 07:12 AM
Baybarea
05-17-07 04:20 PM
erayd8
11-06-02 06:44 PM
