problem...can someone help me? (door actuator)
Old Jun 18, 2007 | 05:58 PM
LexXxuS101's Avatar
LexXxuS101
Unhappy problem...can someone help me? (door actuator)
When I press unlock button driver side wont open. I have to use key in order to open…all other doors work. And when I put in DRIVE all doors r locking except driver side. And I have no idea how fix that. maybe lock broke?.... anyone?
Old Jun 18, 2007 | 06:02 PM
Stage3's Avatar
Stage3
Door lock actuator. It's a common problem with the GS. Sucks...
Old Jun 18, 2007 | 06:03 PM
R.U. IN AW?'s Avatar
R.U. IN AW?
Post Ohhhh the infamous.....
door actuator, I believe there is a groupbuy going on. Check the CL vendors or contact Carson's Toyota @1-800-908-6968 ask to speak to Luis. It's happens to our cars......
-Joe
Old Jun 18, 2007 | 06:11 PM
LexXxuS101's Avatar
LexXxuS101
Tanks guys.
So what should I do? Is it fixble?, cause I kinda have no idea how fix that. I guess auto shop(dealer) is only way?. And how mush is going cost?
Old Jun 18, 2007 | 06:18 PM
R.U. IN AW?
Talking Diy
Tanks guys.
Buy it from the groupbuy or just call Carson's and I'm pretty sure you can install it yourself......someone else can chime in if I'm wrong. But I think it's doable.
-Joe
Old Jun 18, 2007 | 06:23 PM
Stage3's Avatar
Stage3
-Joe
I've heard both, that's it's easy to do yourself, but if you don't have simple knowledge of mechanics it might be a chore. I would at least buy them from the GB... it's going to be MUCH cheaper to purchase them there and have it done than if you were to go to the dealer, purchase the parts and then have them do it. I've heard some pretty stupid numbers as to how much they charge...
Old Jun 18, 2007 | 06:33 PM
LexXxuS101's Avatar
LexXxuS101
So all I have to do is take off side panel and just change that actuator, I don’t even know how its looks like. am gona search maybe there threads about that. I guess am gona call Carson Toyota I got number 1-800-908-6968 and haveto ask Luis. Ok got it. Tanks guys
Old Jun 18, 2007 | 06:37 PM
BAD RIDES's Avatar
BAD RIDES
Registered User
Thats funny my gs 430 just went too same thing
Old Jun 18, 2007 | 07:22 PM
toeb's Avatar
toeb
its not that hard to change did it my self. part from lexus was about $180.00. its worth it
Old Jun 18, 2007 | 08:31 PM
speedaddic's Avatar
speedaddic
door actuators are pretty straight forward
Old Jun 18, 2007 | 10:17 PM
BigManne's Avatar
BigManne
its not too bad to do. i had to do it on my sc. my drivers door in my gs is dead but i have not fixed it yet.
Old Jun 19, 2007 | 06:37 AM
Bill_GS3's Avatar
Bill_GS3
CL Folding 3,000,000
It's not to bad to replace on your own if you want to try it. It is just takes a little bit of time. At the dealer we charge about two hours. I think I read somewhere here that one guy had done his in about an hour and a half.
Old Jun 19, 2007 | 07:16 AM
e-man's Avatar
e-man
A piece of advice to the OP. When you get the actuator fixed, have your dealer turn off the c-best setting that is causing your doors to automatically lock when you put the car in drive. I could be wrong, but I believe that feature is triggering all 4 actuators even if only the driver's door is unlocked and the passenger and back doors are already locked. Because this is a known problem with the 2GS, I try to use the actuators as little as possible.
Unless I need to get into the passenger side of the car or the back seat, I only hit the remote button once to unlock the driver's door. Once in the car, if I want to lock the driver's door, I manually lock the button from the inside. Also, when I exit the car, I manually unlock the car from the inside, open the door, and then manually lock the car before closing the door. What's interesting is that if the headlights are on, whereas you would normally have to hit the lock button on the remote twice in order to turn off the headlights, if you manually lock the driver's door prior to closing the door, the lights go off on the first click of the remote. Anyway, I guess this is a little OCD on my part, but the point is to use the actuators as little as possible because they are prone to break and I don't feel like having to replace them.
e
Old Jun 19, 2007 | 06:23 PM
Chenzo26's Avatar
Chenzo26
Its not a bad little DIY project to bang out. It kinda sucks that it happened on the ONLY door that really matters. I guess Murphy's Law is in full effect
wvk14
Sep 25, 2016 01:09 AM
aespinalIS
Feb 26, 2015 10:10 AM
jsc8686
Mar 7, 2012 06:08 PM
Slow_Sc3
Feb 14, 2009 03:24 PM
atl4love
Mar 5, 2008 04:08 PM
