Have a new rattle....need help
Old Mar 7, 2007 | 04:38 PM
Joelseff's Avatar
Joelseff
Default Have a new rattle....need help
Hi all,
I searched but only found the dreaded sunroof rattle(which I have but this rattle is new). Yesterday a rattle started that seems to be coming from either the headliner wher the rearview mirror is mounted or inside the center stack it rattles when I hit small bumps and I can now hear it while the radio is on Anyone here have the same prob???
Old Mar 7, 2007 | 04:57 PM
h0t SaUc3's Avatar
h0t SaUc3
I'm not sure about that rattle, but when i hit small bumps i know my gauge cluster rattles. Go over a bump and hold it tightly, if you still hear the rattle then I ddint help you one bit.
Good Luck
Old Mar 7, 2007 | 05:06 PM
siko's Avatar
siko
you know the quick and easy fix for this is right? turn up the volume
Old Mar 7, 2007 | 05:18 PM
chrispy's Avatar
chrispy
is this when your sunroof is slid open and not tilted? if so, after it's open, press and hold the switch back and it should slide back just a bit. it should keep the headliner from rattling.
Old Mar 7, 2007 | 06:15 PM
Joelseff's Avatar
Joelseff
It's not the sunroof although I do have that rattle too. It may be the gauge cluster but it sounds like its coming from the top of the car. It's really annoying
Old Mar 7, 2007 | 10:32 PM
Joelseff's Avatar
Joelseff
FOUND IT!!!!
it's coming from the overhead light thingymajingy. i ggave it a couple of good thumps and it reproduced the rattle. How do i take the headliner apart???
Old Mar 8, 2007 | 06:03 AM
skurks507's Avatar
skurks507
it's the plastic covering the Homelink unit. I have the same problem too. Any ideas on how to fix it would be greatly appreciated
Old Mar 8, 2007 | 08:25 AM
slickgt1's Avatar
slickgt1
Hmm, I never though of that. Maybe thats where my annoying rattle is comming from.
Old Mar 9, 2007 | 04:25 PM
Joelseff's Avatar
Joelseff
Originally Posted by Joelseff
FOUND IT!!!!
CRAAAPPP that's not it. I took the dome light assembly apart and Couldn't find squat. I think now it's in the headliner by the driver side sunvisor. All i did was bend some clips on the light assembly and if you push up on the headliner you can see a gap between the assembly and the headliner...... I am gonna have my buddy who is a Lexus tech check it out. he says he has extra felt so this weekend we might try to find the culprit....
Old Mar 21, 2007 | 11:32 AM
Joelseff's Avatar
Joelseff
Okay FOUND IT and FIXED IT!!!!
I took the headliner apart and found an aftermarket hands free microphone antenna, thought that was it...nope. I removed the Mic, wires and brain, still rattling. My buddy who is a lexus mech, popped the hood and found that the battery tie-down had come loose and was banging on th firewall....Long story short, tightened it down and now NO RATTLE!!!! I still have the other creaks which are easily muted by the radio
SirThadeus
Jun 21, 2011 06:25 PM
Booyah
Oct 1, 2007 07:44 AM
Threxx
Oct 4, 2005 03:10 PM
FlintRX
May 31, 2004 07:40 PM
