Replacing ECU on 98 GS400
Old Mar 2, 2007 | 12:34 PM
dglange's Avatar
dglange
Default Replacing ECU on 98 GS400
98 GS400. Lexus dealer said my ECU is malfuntioning It's isn't sending power to the Var. Valve Timing. They said ECU needs to be replaced. $1600 plus labor. I found a used ECU for $300. Can I just plug it in and drive or do I have to have the master key that went with the $300 ECU?
Dennis
Old Mar 2, 2007 | 12:51 PM
salimshah's Avatar
salimshah
25 Year Member
Not confirmed, but there are limited slots for the master key in the ecu. You can potentially reprogram the ecu to new master key (dont know how) but if all slots are taken then you have to use the pre-registered key.
I wish I knew the above for a fact but do the home work before you plunk $300 down.
Salim
Old Mar 2, 2007 | 01:02 PM
dglange's Avatar
dglange
Thanks, any ideas how to find out. The dealer doesn't want to spill the beans.
Old Mar 2, 2007 | 06:58 PM
BLAZE's Avatar
BLAZE
Have them run your vin #, to see if your car was a part of the ecu re-call. I got mine done free of charge. They just might think it was never a re-call issue or your car could be out of the affected range. Good luck
Old Mar 2, 2007 | 10:16 PM
dglange's Avatar
dglange
I will call the dealer monday and post an update. Thanks
Old Mar 3, 2007 | 04:47 PM
GILLEXUS's Avatar
GILLEXUS
Try Darrel from Sewell Lexus he is always running Key group buys or Jason of JPI. They might be able to shed some light.
LexBrett
Sep 20, 2015 03:56 PM
pfu920
Sep 11, 2010 11:06 PM
CLEV
Apr 30, 2007 04:24 AM
