SC430 vs GS430 offset
Old Mar 3, 2007 | 06:49 PM
YeShrug's Avatar
YeShrug
Default SC430 vs GS430 offset
http://cgi.ebay.com/ebaymotors/ws/eB...m=300085167645
Any reason why these shouldn't fit? Hope not
Old Mar 3, 2007 | 08:21 PM
ARISTOh's Avatar
ARISTOh
why not? they should fit fine... not too bad either
Old Mar 3, 2007 | 08:54 PM
Neo's Avatar
Neo
The One
Are you asking for a 2GS? 20x9 +37 will be pretty flushed up front and will require some tweaking. This setup in the back unfortunately won't be as aggressive.
Old Mar 3, 2007 | 09:05 PM
YeShrug's Avatar
YeShrug
yea 2G, am I looking at some rubbing during turning or more serious complications? I'd been eyeballing them, but decided to make the jump. Before I submit the paypal (and this is my first ebay offense) wanna make sure this wont be a pita.
Old Mar 3, 2007 | 09:25 PM
Neo's Avatar
Neo
The One
I assume you are going to lower the car too.
They are 20s so you will get some rubbing of the wheelwell liner. At some point, you will probably wear through certain areas. You can avoid some of these areas by reshaping them out of the way with a heat gun. You might also need to roll the fender lip and the two tabs that you will see in there.
Dips and turns will also be hit and miss. Remember though that some of these problems are 20s related and not specific to these specs. Also, stay with 245s as 255s will definitely get you into trouble. If you want to get rid of the "20s" problems and are OK with thinner sidewalls (and a little worse ride quality), you can go to 245/30s.
gs4thirty
Nov 19, 2012 10:51 AM
Billh2
Wheels, Tires & Brakes Forum
Nov 19, 2005 03:44 PM
Hermosa
Mar 9, 2005 08:32 PM
rookie619
Feb 23, 2004 01:18 AM
DPRSupra
Apr 7, 2003 07:38 PM
