upgrading wheels...
Old Nov 22, 2006 | 04:26 PM
uplusd's Avatar
uplusd
CL Folding 100,000
Default upgrading wheels...
How big of an impact do upgrading the wheels have on the ride quality of the car? I'm thinking about upgrading the stock 16s to some 19s, but I don't want to ruin the smooth luxury feel of the car.
Thanks.
Old Nov 22, 2006 | 05:14 PM
BAD RIDES's Avatar
BAD RIDES
Registered User
Default I have 19s
Thanks.
I have 19s in a staggered set up and love them my wife drove my car the other day and said she couldnt feel a diference as well
Old Nov 22, 2006 | 05:20 PM
GREED777's Avatar
GREED777
Most here will tell you that the best upgrade in wheel size without ride degradation is 18's. You will notice some differences with a larger wheel, not neccasarilly while rolling but going over bumps, pot holes etc. Do you have any suspension mods? Your tire set up will also make a slight difference.
Old Nov 22, 2006 | 05:21 PM
BAD RIDES's Avatar
BAD RIDES
Registered User
Default Here is what they look like
here a pic
Old Nov 22, 2006 | 05:24 PM
uplusd's Avatar
uplusd
CL Folding 100,000
My car is bone stock, I'm planning on adding wheels and that's it. No springs, shocks, or anything.
Old Nov 22, 2006 | 05:34 PM
GREED777's Avatar
GREED777
Well again, if your primary concern is ride quality 18's are probably the way to go. 19's and 20's are usually more attractive and give you the look that you are trying to achieve. The larger the wheel, the less sidewall, the less the sidewall, the more you are going to feel on the road. I personally found that the 19" set up that I have is still very comfortable, did I loose ride quality, yes. Was it worth it, absolutely. It's all a matter of personal comfort.
Old Nov 22, 2006 | 05:36 PM
chuckb's Avatar
chuckb
I wouldn't get any bigger than 17s then or it will look funny.
Old Nov 22, 2006 | 06:18 PM
GREED777's Avatar
GREED777
Chuck has a great point, if you go with a larger wheel and no suspension mods you will have a large wheel gap and it probably won't look right. You may want to do some searching throughout the gallery and get some ideas on how different wheel sizes look with different ride heights, and how this plays into the look that you're trying to achieve.
Old Nov 22, 2006 | 06:36 PM
D2-AUTOSPORT's Avatar
D2-AUTOSPORT
Former Sponsor
From a standpoint of the ride alone, a 19" fat setup with no suspension mods at all will feel very close to OEM
Old Nov 23, 2006 | 05:06 PM
SoCal_VIP's Avatar
SoCal_VIP
I upgraded to 19's staggered and I don't feel a difference at all. I felt most of the difference when I installed my HA's and slammed them. But if you are going to go 19s staggered or not atleast lower it 1-2"s or it will look a little funny.
Heres a pic of my GS on 19's ...
Old Nov 23, 2006 | 10:26 PM
oojpeeoo's Avatar
oojpeeoo
i have mine on 19s staggered with tein flex suspension and honestly its not that bad, could barely tell the difference
Old Nov 24, 2006 | 06:22 AM
girlilove's Avatar
girlilove
Hey VIP, do you get any rubbing in your rear tires? What tire width are you running on?
Old Nov 24, 2006 | 10:03 AM
yelnoc's Avatar
yelnoc
Either of you have vibration or alignment problems? I just traded an 02 Mustang GT for an 03 G430. The Mustang came with really low profile 17s and sorely needed an 1" or so of lowering. Evidently the after market caster/camber plates allowed enough adjustment that never heard any lowered Mustangs having problems contrary to this board where you read of quite a number of vibe/alignment problems that give folks fits.
I have the stock chrome 17s and like them ok - but will wait until I need tires and get a package so wife won't notice.
Old Nov 24, 2006 | 12:11 PM
SoCal_VIP's Avatar
SoCal_VIP
I have no rubbing issues at all. No shaking or vibration, I use to have that issue but I had the front control arms and bushings replaced..solved that issue fast. Listed wheels specs below..
Front
19x8.5 +28mm offset w/5mm spacer
225/35 Toyo Proxy4 tire
Rear
19x9.5 +22mm offset w/no spacer
245/35 Toyo Proxy4 tire
My tires are stretched which helps in no rubbing alot. I also trimmed the litte 1" inner fender trim off the rears and rolled the fronts with a bat. Even with the car with 4 people, luggage I still don't rub. The mufflers do but wheels dont at all..hope this helped.
Old Nov 25, 2006 | 06:23 AM
Stefwilli's Avatar
Stefwilli
Wheel Vendor
19" with a fat tire set up along with still having your luxo ride you will also notice improved handle, something you'll like.
