Replacing '99 GS300 Master Window Switch
Old Oct 27, 2006 | 07:53 AM
BDiccus's Avatar
BDiccus
Default Replacing '99 GS300 Master Window Switch
Greetings,
I need to replace my a broken MWS and wanted to know if I have to remove the entire door panel to replace it. I've done a search and seem to only find 1st gen and RX door panel instruction.
Thanks for any help.
Biggus
Old Oct 27, 2006 | 08:14 AM
cliffud's Avatar
cliffud
Former Vendor
Check out one of the masters of DIY on ClubLexus.com -
BananaGS: http://lexusmodz.netfirms.com/
Old Oct 27, 2006 | 08:38 AM
BDiccus's Avatar
BDiccus
Thanks but there's nothing specific for removing the door panel or replacing the master window switch.
Old Oct 27, 2006 | 08:59 AM
movinquick's Avatar
movinquick
under interior section installing polk audio 6.5 speakers in the front door tells you how to remove the door. i think once you got that off you can just replace the old master switch with the new one.
Old Oct 27, 2006 | 10:51 AM
cliffud's Avatar
cliffud
Former Vendor
thanks movingquick - i was pretty sure there was a DIY on there about how to remove the door panel.
replacing the window switch can't be that hard... just unplug - unscrew it or snap it out and swap with your new one.
good luck bdiccus.
Old Oct 27, 2006 | 12:57 PM
SloGS3's Avatar
SloGS3
Yes you would have to remove the door panel and then take the swith off. I did this not too long ago after 3 of 4 window buttons decided to just snap off. I hope you got a used master switch from somewhere, because Lexus is very proud of theirs, $385 proud. Mine are still just on there broken, I can use the windows but they wont go up automatically like before. Taking the door panel is easy, just be careful not to break any plastic. Good luck!
Jerry1948
Sep 9, 2018 07:06 AM
gtstcactus
Feb 11, 2014 07:29 AM
loccsta187
Jul 5, 2011 07:38 AM
hulla
May 20, 2009 05:53 PM
elhill
Dec 30, 2004 08:27 AM
