Broke your ABS/VSC sensor? Here's how to fix it!
Old Oct 14, 2015 | 05:52 AM
  #76
PandaGS300's Avatar
PandaGS300
Hello,
Does anyone have pictures to this?
Old Mar 15, 2017 | 08:36 AM
  #77
Robb92914's Avatar
Robb92914
Originally Posted by JeffTsai
Sorry the original pix are gone. Had a server crash back like 2 years ago lol.
My GS400 needs to have one of the ABS sensors repaired. I'll make a new guide soon and update this posting.
I know it's been a few years but do you or does anyone have or know where I can find a diy?
Old May 3, 2018 | 04:44 PM
  #78
carmar8791's Avatar
carmar8791
For some reason I cant see any of the pictures?
Old May 13, 2018 | 12:21 AM
  #79
NIXmx's Avatar
NIXmx
This sacred information is lost forever.
Old Dec 6, 2020 | 08:59 AM
  #80
LucasJZS's Avatar
LucasJZS
Can the thead owner restore the pics?? Thanks in advance
Old Dec 8, 2020 | 10:30 PM
  #81
JeffTsai's Avatar
JeffTsai
I had some people notify me that the photos are down. I will try to recover the photos. I changed my hosting a little while ago and a bunch of the photos are messed up.
Old Dec 9, 2020 | 01:10 AM
  #82
LucasJZS's Avatar
LucasJZS
Thank you!
Old Sep 3, 2021 | 01:59 PM
  #83
schmauster's Avatar
schmauster
I'm in the same boat with the abs connector needing to be disassembled. Anybody willing to take their apart and take pics??? Haha
I joined to post this!
Old May 13, 2022 | 03:23 PM
  #84
caverman's Avatar
caverman
Sorry I'm resurrecting an old thread but I'm trying to get some confirmation on the sensor. I had a ball joint fail on driver side on an '01 GS300. After replacing it, I got the ABS warning light on the dash. I checked it with volt meter and couldn't get a reading. I tested the passenger side and got 1.67 ohms. These sensors are still going for about $135+shipping off of RockAuto so I rolled the dice on a cheap set off of eBay. I checked the new sensor and it was reading about 155 ohm. I went ahead and replaced it but I still have the ABS warning lights.
So, the questions I have are
1. Is 155 ohm too low for it to work and I need to find another sensor? Do I need to find one that measures in the 1.6-1.7 range to fix it?
2. If I do end up replacing the sensor with a good one, does the ABS automatically go off if all is good or do I need to go to a dealer and have the warning turned off with Techstream or something similar?
Old May 12, 2023 | 04:37 PM
  #85
lastguy's Avatar
lastguy
Thanks for original post, I can hardly know due to know photos. I update this in case others needed.Gen2 GS300 front parts are R/L: , here is cheaper one:
Amazon Amazon
remove 10mm bolt on the Knuckle, pull the sensor out, then trace cable path to remove a few 10mm bolt/screws - inc those around the plastic cover and under the car.
You need to go under the car, pull the bottom plastics which covers the windshield reservoir (say Left side), you will see last clip and the connector. Snap and pull out the plug you get sensor free.
it shall have 1.6-1.7Kohm or 1-2,5Kohm, if you spin the hub ~1/2rps, you would read 0.1-0.2V AC.
I replaced lower control arm No.2, hammer ball joint that causes the sensor broken. Got one from Amazon for $25+2 in 24 hours- thanks for made in China deadly cheap <10% of genuine price. This car uses passive sensor or a coil with magnet.
Amazon Amazon
1NICESC430
Aug 20, 2018 01:16 PM
duckJAI
Oct 9, 2016 06:54 PM
peewhy
Apr 12, 2010 02:28 AM
taeng
Oct 22, 2008 05:07 PM
drewefx
May 17, 2008 08:13 PM
