so i was just driving down a major highway and all of a sudden i hear "thud-thud-thud-thud" sound coming from the front as if i have a flat, so i pull over, and no flats
then i get back in my car put my seat belt on and prepare to drive away and "clunk-clunk-clunk" i have NO clue what this is. i get out 4-5 times and check underneath the car and drive a few feet each time. the steering wheel is now also shaking
now OBVIOUSLY you cant really diagnose my problem from this description, but any idea
Quote:
haha, the tires seemed properly inflated... none of them were low Originally Posted by TLW
Did you check the tire pressure ?
Let's hope something's not actually broken, but here's a guess. Is something wrapped around the disc brake area?
Quote:
no, i looked and didnt see anything wrapped around it... something broken?? Originally Posted by GWELEX
i hope not, but something is DEFINITELY wrong
Another off the wall guess, bad tire with a blown sidewall. Have you dropped it into a pothole or ran over something recently?
Quote:
That's what I was thinking alsoOriginally Posted by STONER
maybe a busted ball joint?
Former Vendor
Immediately check that the wheels are properly torqued down! A wheel not properly torqued down will create this kind of sound.
This happened to me too, but the clunking noise only happens when I'm turning. When I looked under my car, my sway bar was lose. You have 3 bolts that hold your sway bar. I had 2 loose and the 3rd fell off. You'd probably want to check your swaybars too.
Quote:
Did you just look at the tires or did you check the pressures with a gauge? Some of the low profile tires have side walls stiff enough to not visually notice that there is a flat? This has happened to me before. I didn't realize I had a flat until I took out the tire gauge.Originally Posted by varcity64
If the tire pressures aren't the problem, do you have a dead body in the trunk?
steering rack need to be tightened? I know this used to be a common problem for our cars.
Quote:
how do you tighten the steering rack?Originally Posted by ebruce2
Quote:
so i had the mechanic look at this morning and thats what it was Originally Posted by Tanabe USA
yea, i guess i need a nice
Former Vendor
Luckily you caught it, and you didn't snap any bolts or have a wheel come off while driving.
Checking that the wheels are properly torqued down is the first thing to check whenever you hear something like this. Glad that you're still with us!
It's not uncommon for a shop to be careless and not properly torque down the wheels. Don't forget to recheck the torque after a few days.
