Help Connecting Spoiler
Old Jul 7, 2006 | 08:59 PM
Ckroush's Avatar
Ckroush
Default Help Connecting Spoiler
I've looked at BananaGS' website but it's still not helping me. I bought the car used with the spoiler but it's never worked so I figured I'd check into it today. Tell me whats wrong with this picture. Both red/black wires come from the spoiler. No idea where yellow/green and white/black come from. That plug isn't connected to anything. It just hangs there
Connection Pic
Old Jul 7, 2006 | 10:30 PM
GSteg's Avatar
GSteg
What's the problem? The lights dont turn on?
Old Jul 8, 2006 | 07:21 AM
Ckroush's Avatar
Ckroush
haha yeah it might have helped if i said that. the spoiler light doesnt work and I'd like to get it working and disconnect the third brake light. i just dont understand whats wrong with my connection
Old Jul 8, 2006 | 08:01 AM
Dx3's Avatar
Dx3
Connection Pic
Post the link to Banana's write-up.
Jonny
Old Jul 8, 2006 | 10:10 AM
Ckroush's Avatar
Ckroush
http://lexusmodz.netfirms.com/GS_DIY/spoiler
In figure 10 he shows two plugs.. I only have the one that holds the yellow/green white/black wires. And what is that red plastic thing around the white/black and yellow/green wires?
The plug I have doesn't come from the spoiler. I have my Red connected to the yellow/green and my red/black connected to the white/black. Just like it says
Do you think maybe the led bar needs to be replaced? The previous owner is no help because... he can't remember if it ever worked or not
Old Jul 8, 2006 | 10:14 AM
Dx3's Avatar
Dx3
I would start by getting a light tester or a voltmeter to test and see which of the wires are hot. Then I would go from there to see if you are connecting the right wires.
The picture is too small to see what the red thing is. Look like some type of connector.
Jonny
Old Jul 8, 2006 | 10:15 AM
samster's Avatar
samster
mabe its an aftermarket spoiler? and not OEM so the LED bar wires are red n blk
aslong as u hook those wires to any brake light it will go off if it works
Old Jul 8, 2006 | 10:20 AM
GSteg's Avatar
GSteg
Just wire the spoiler's wire in parallel and you should be good. The lights on the spoilers (if OEM) are LED so they aren't taking a lot of current. No need for relays here.
__________________
1999 Lexus GS400
-Stock
MUAHAH
Old Jul 8, 2006 | 10:43 AM
Ckroush's Avatar
Ckroush
well guys not too good. I was using a light tester so I needed to hold the brake light down to provide the juice. I used a 10lb weight to hold the brake pedal down. I guess trying to get the weight situated and pumping the brake too much wasnt a great idea, because now my car is stuck in park. I can only move the shifter about a millimeter. I should just take it somewhere. I always screw up the DIY
Old Jul 8, 2006 | 11:10 AM
Ckroush's Avatar
Ckroush
I definately need help guys... My car is absolutely stuck in park and ive got three lights on my dash.. ABS, VCS, and VCS Off
Old Jul 8, 2006 | 11:13 AM
GSteg's Avatar
GSteg
This is why i only use a DMM when testing electrical system
__________________
1999 Lexus GS400
-Stock
MUAHAH
Old Jul 8, 2006 | 11:14 AM
Dx3's Avatar
Dx3
OK, did u try putting something in the shifter lock hole and moving it that way? Did you blow a fuse or anything??
Jonny
Old Jul 8, 2006 | 11:16 AM
Ckroush's Avatar
Ckroush
I dont think it's a fuse... if it is though.. should i check under the kick panels or under the hood... let me try the shift lock... how does that thing work anyway?
Old Jul 8, 2006 | 11:21 AM
Dx3's Avatar
Dx3
Yeah,
You are going to need to check all your fuses as there is something stopping you from moving it. I would check both but start at the kick panel.
You just need to insert something into the lock to disengage it. Like a flat head screwdriver for instance.
Jonny
Old Jul 8, 2006 | 11:27 AM
Ckroush's Avatar
Ckroush
Thanks!! It was the shift lock dont know why it took me so long to think of that one... now ive got a worse problem that i think pertains to the warning lights... After I got it into drive, i took it for a spin testing the brakes... Every single time I start slowing down... as soon as im almost stopped.. i get a thump and a jarring sensation out of the back of the car. Its like going over a pothole at like 5 mph
