Cel P0446
Old Jul 7, 2006 | 06:42 AM
Ronsully's Avatar
Ronsully
Default Cel P0446
I know, I know. I already searched this code and came up with some good answers.
I am wondering if the canister is a DIY. Where is this sucker located...? I know in the supra it is in the top passenger corner of the engine compartment.
Also, the part appears to be pricey. Does anyone know if I can use the canister for the supra (either the TT or NA) in the GS300. Are the part numbers interchangable. A lot of supra just throw the canisters away.
Old Jul 7, 2006 | 03:23 PM
RTIS250's Avatar
RTIS250
Yes. I drove the LFA.
CL Folding 500,000
Extremely highly doubt there is an interchangable part number from another vehicle... even a Supra. The canister, is above the rear differential. It can be done as a DIY, but it can be pretty involved, depending on how mechanically inclined you are. Good luck with everything... But, are you sure its a canister leak? P0446 can be a VSV problem, a broken vaccuum hose... or any number of things... i would check the valve and hose right by your intake box.. among other things...
Old Jul 8, 2006 | 01:50 AM
tonysofly's Avatar
tonysofly
like RTCamaroSS said, it can be many things, don't go changing your canister for no reason. It can be a simple problem like forgetting to tighten your gas cap, or a bad gas cap. My car threw off that code because my gas cap was bad. but check it through before you waste money.
Old Jul 10, 2006 | 09:47 AM
Ronsully's Avatar
Ronsully
Thanks fellas. I will start with checking the vac lines.
Any help on locating where the VSVs for this system are located.
Wicked SC
Florida Lexus Club
Jul 28, 2014 09:20 PM
supercoupes
May 11, 2004 10:47 AM
SC300TURBO
May 21, 2001 08:09 PM
SC300TURBO
IS - 1st Gen (2001-2005)
May 21, 2001 09:29 AM
anthracitetarga
Apr 25, 2001 02:17 AM
