A/C issue
Old Jun 19, 2006 | 01:22 AM
PHML's Avatar
PHML
Master Thread Closer!!
Default A/C issue
Anyone ever had this happen?
A/C is running at 65 degree setting....on Recycle Air mode.....air is NOT cold.....then Recyle mode switches to Outside Air mode by itself (click sound). Still NOT cold. I hit Recyle manually....again it switches to Outside Air mode. Continues to do this for the next 5 times.
Turned off the engine....restarted the car....and still does the same thing.
I got home and popped the hood....put the A/C gauge on there.
I got plenty of R134a in there....just refilled with small can last month. Is this due to overfill? My gauge says im in the green level (good)......closer to yellow level (warning).
I let some R134a out from the low side....gauge is now in middle of green level....seems ok now...and blowing cold.
Pete
Old Jun 19, 2006 | 01:40 AM
JeffTsai's Avatar
JeffTsai
It was probably just due to you overcharging the system, if it started working after you let some out.
Old Jun 19, 2006 | 06:05 AM
SloGS3's Avatar
SloGS3
This happens to me from time to time, i just set the fan on 3 bars and it starts blowing cold withing a minute or so. Its strange, makes me wonder if there is anything wrong. I checked my r134 level as well, and it was showing that my system was overcharged, i never did anything to it in the past year and a half that ive had the car.
kent2174
RX - 4th Gen (2016-2022)
17
Mar 10, 2020 12:56 PM
jcoukos
Jan 4, 2013 05:02 AM
ancdmd
Aug 15, 2010 08:18 PM
LVLarry
GX - 1st Gen (2003-2009)
15
Feb 19, 2008 04:37 PM
RacingLuxury
Jul 1, 2007 01:17 PM
