OMG! am i screwed?!?!
Old Apr 18, 2006 | 06:33 PM
Kharizma's Avatar
Kharizma
Default OMG! am i screwed?!?!
ok so i'm changing my spark plugs, right?
i start on the passenger side... easy enough.. got all 4 changed.. ok la dee da..
so then i start on the driver side...
first off, it's a pain in the *** to reach the damn screws.. so i finally get the first one loose (the one closest to the front of the car) and then i detach the little wire clip thing from the coil pack.. then i proceed to take off the coil pack and *POP* the top part comes off but the rubber tube with the spring inside is still stuck in the pipe!!!
anyone know what i can do? if i take it to lexus, do you think they'll be able to fix it?
WHAT DO I DO?! so right now i only have 4 TM plugs in and 4 DENSO OEM in.. how long do i have? is my car safe? should i be driving it around or not?
i need ALL things i need to watch out for 'cause i don't know anything about cars and i don't think Lexus can get me in for the most - a week..
Old Apr 18, 2006 | 06:45 PM
Kharizma's Avatar
Kharizma
oh and i have a 2000 GS400
also, this guy said that he thinks the SPRING is actually wrapped AROUND THE SPARK PLUG END? that didn't make sense to me because when I look at it, it doesn't look wide enough or long enough to come down and wrap around the spark plug...
Old Apr 18, 2006 | 07:51 PM
Kharizma's Avatar
Kharizma
anyone? lol i'm so worried
Old Apr 18, 2006 | 07:56 PM
chuckb's Avatar
chuckb
Default sorry to hear man.....
so you broke the boot off the coil pack? you should call Darrel Diller/Sewell Lexus and have him overnight you the part.
Old Apr 18, 2006 | 07:59 PM
maintrain's Avatar
maintrain
Old Apr 18, 2006 | 08:00 PM
trbopooh's Avatar
trbopooh
Same thing happened to me. Just use some wd40 and spray a little in between the boot and use a pair of long needle nose pliers to wiggle it free. The coil pack can be reatttached to the spark plug boot with no problems unless it's damaged when you get it out.
Old Apr 18, 2006 | 08:05 PM
trbopooh's Avatar
trbopooh
Oh yeah, forgot to add don't yank on the boot too hard cause it'll rip it. Try to see if it'll move from side to side. It should pop right out.
Old Apr 18, 2006 | 08:08 PM
Kharizma's Avatar
Kharizma
awesome, i'm gonna spend some time on it tomorrow and keep wiggling it til it comes loose glad to hear that i can re-use the boot lol
Old Apr 18, 2006 | 08:11 PM
trbopooh's Avatar
trbopooh
No problem. As long as the boot's not torn and the spring inside is not all mangled, you can just reattach it to the coil pack. Just remember to be patient and work it loose.
thefitboi
Maintenance
Feb 25, 2015 08:07 AM
R4a2m0o
Jul 1, 2014 06:29 AM
McKrevice
Apr 21, 2010 12:18 PM
lex4
May 24, 2006 11:10 PM
TOMLEXUS
Performance
Mar 30, 2005 09:45 PM
