GS400 Starter problem?!
Old Mar 26, 2006 | 01:41 PM
ShaneC's Avatar
ShaneC
Default GS400 Starter problem?!
2000 GS400 w/ 82xxx miles.
2 weeks ago I started my car in the morning and noticed a scraping noise coming from the engine bay. I pulled the car out of the garage and thought it may just go away if I drive it.. so I got it on the road... I drive about 2 car lengths and I saw the check engine light and VSC or VCS were on. Didn’t feel right so I turned the car off, but when my key was on the off position I still heard a scraping noise. Sounded like the motor was still spinning and scraping something. My neighbor (a mechanic) he heard my car and took a quick look and said it was my starter and it was not disengaging.
So I parked my car back in the garage and got a different ride. Next morning I started the car up and it ran fine. Check engine light was still on so I went to a friends shop and pulled the engine code and I think it was the crank sensor. Vsc light went off.
Maybe the started fixed it self.. but I changed the starter anyways because I figure it was a sign the starter was going bad. (pain in the *** to change a V8 starter.)
I wanted to know if anyone else had this problem. Common problem? and do you think its a smart move to change the starter?
i havent had any problems since
Old Mar 27, 2006 | 06:50 AM
Tammy's Avatar
Tammy
Starter solenoid motor contacts tacked closed due to arcing, causing constaint run of starter.
Agreed with starter replacement as problem resolution.
guzzy92fs
Feb 14, 2025 12:16 PM
mbrown1782
Jan 18, 2013 08:17 AM
GSXLEX
Maintenance
May 31, 2009 07:11 PM
mosesgolf
Jan 23, 2007 04:28 AM
biggie27
Aug 26, 2004 04:24 PM
