Need help....engine stopped while driving
Old Feb 23, 2006 | 09:24 AM
49GS400's Avatar
49GS400
Default Need help....engine stopped while driving
Need some help guys. As I was driving in the parking lot looking for parking my car all of a sudden turned off. There was power but the engine just stopped. I was picking up my daughter from school and luckily I was in the motion parking the car and the momentum let me fully park. But right after I turned off the car and fired it back up. Everything started fine. I was able to turn it off to pick up my daughter and it started up fine for me to go home and to work the next morning. Not sure what it was but I dont want it happening again.
I know I remember reading here where some people had the same problem but there's happened on the freeway. Anyone remember or know the cause of this. I want to get this fixed ASAP. Thanks for your help.
Old Feb 23, 2006 | 09:28 AM
rominl's Avatar
rominl
exclusive matchup
let me guess, you were going pretty slow and you didn't have your ac on? that's a common problem in that case, the low idling problem. just keep your ac on
i have never heard of the car shutting down on freeway though
Old Feb 23, 2006 | 09:32 AM
49GS400's Avatar
49GS400
Thats all correct. But any other solution than keeping AC on? Since its been really cold lately and I catch colds too easily, that probably not an option.
Old Feb 23, 2006 | 09:33 AM
rominl's Avatar
rominl
exclusive matchup
hahaa, then turn on the heat? j/k
you can work on the throttle wire a bit and tighten it up to raise the rpm just a slightest bit and it will help
rominl's Avatar
rominl
exclusive matchup
btw you are in cali? come on, my ac is on all the time. just set a temp!
Old Feb 23, 2006 | 12:55 PM
CK6Speed's Avatar
CK6Speed
So they never found a fix for this low idle problem? I have that happen on my 93 SC400 using the old 1UZ-FE engine. Fortunately we use the AC almost constantly in Hawaii so it is not that bad of a problem, but sometimes when I don't have the AC on it catches me by surprise when the car dies. Anyway, does this affect the GS430 4.3L engine as well?
Old Feb 23, 2006 | 01:13 PM
49GS400's Avatar
49GS400
I took the car out at lunch and as I was sitting at a stoplight on the hill I noticed the car sounding slightly rough. Wouldnt you know, I checked my idle and it was hanging a little too low. Hit my AC and was on my way. LOL. Thanks Rom.
But really I need to get this fixed. I've had this car for a little over a year. Its a 2000 GS4 model, bought it used and never had this problem before.
Old Feb 23, 2006 | 05:09 PM
blue99GS4's Avatar
blue99GS4
Oh! So that's the low idle problem. It happened to me three times since last year but never knew what it was. I wonder if cleaning out the throttle body help?
Old Feb 23, 2006 | 05:53 PM
chuckb's Avatar
chuckb
turning the lights on, even just to first click(parking lights) has the same effect as turning on climate control.
Old Feb 23, 2006 | 06:16 PM
rominl's Avatar
rominl
exclusive matchup
definitely try to adjust the throttle cable a bit. rmmgs4 did it and seems to fix the problem
for me i never have to worry about it so i am cool
8E0S8
Sep 19, 2015 06:17 PM
Justin2JZ
Dec 7, 2011 02:16 PM
EN_VY
Sep 17, 2010 02:07 PM
nerdyimage
Jul 8, 2010 08:44 PM
mccube
Apr 25, 2008 07:54 PM
