Dripping....
Old Aug 18, 2001 | 11:38 AM
LexusRules's Avatar
LexusRules
hey guys, i know this is probobly normal but whenever i turn off my car it starts dripping stuff.. i dont know what it is but i know that its not gasoline. Either oil or coolant. I found that it is coming from a hose pointing at the ground, so its not a leak... what is it?
and will and oil catch tank besomething i should use to stop it?
thanks guys
Old Aug 18, 2001 | 11:50 AM
dzman's Avatar
dzman
If it is coming from a hose in front it is most likely coolant from the radiator overflow reservoir.
Check the plastic coolant reservoir per owner's manual. There is a line on the side marked "full hot". Coolant over this line usually expands and drips out as it is designed to do.
As long your temp guage is normal there is nothing to worry about
Later
DZMAN
Old Aug 18, 2001 | 12:36 PM
Perfectly normal Sasha - it's condensation from the air conditioner. Stick your finger in the puddle of water - it probably doesn't smell at all, and may (although I wouldn't recommend it) be drinkable.
Old Aug 18, 2001 | 12:55 PM
LexusRules's Avatar
LexusRules
yes its oderless,
i'm just wondering, lets say i was drag racing the car, would i like be kicked off for dripping? i know this one guy was disqualified and couldn't even run because he was driping, will it not happen if the AC is off or car is on? thanks man
Old Aug 18, 2001 | 01:34 PM
HI98GS's Avatar
HI98GS
Track officials hate it when water is placed anywhere else other than in the burnout box. If you are gonna go to the track, just make sure that when you arrive, you turn off the AC before you go racing. About 5-10 min before your race should be sufficient, that way you don't drip water onto the track. Water+Drag strip=no traction and possibility of major accident.
have fun
aloha
ricky
Old Aug 18, 2001 | 01:43 PM
yes its oderless,
If the AC is on while the car is on, it will drip. When you turn the AC or car off, it will contunue to drip a bit.
So to make sure you're not dripping, keep the AC off.
Old Aug 18, 2001 | 02:36 PM
D-MAN63's Avatar
D-MAN63
Yeah, I drink it all the time. Nothing wrong with me.
Heu aomc wyqp dnei fugh huh?
Old Aug 18, 2001 | 03:02 PM
LexusRules's Avatar
LexusRules
ROFLAMO!
thanks bit
Old Aug 18, 2001 | 03:38 PM
Mee toooo hoooo woo ha ha ha mwahahaha nyuk nyuk hubba hubba
Ah, better now.
Old Aug 19, 2001 | 04:34 AM
mooretorque's Avatar
mooretorque
D-Man, Bit, I think you guys must be spendin' a little too much time hittin' the brake fluid!!
Old Aug 19, 2001 | 08:00 AM
lexguynj's Avatar
lexguynj
Yes it is the condensation from the AC unit in the car.
My car pisses a heck of a lot of water, it looks like something burst under there at times. ;-)
Old Aug 19, 2001 | 11:11 AM
2Lexos's Avatar
2Lexos
Chicago Lexus Club Moderator
if you guys are really adventurous try sniffing brake dust........ i'm not a fish......i'm a man:eek:
Old Aug 19, 2001 | 04:17 PM
D-MAN63's Avatar
D-MAN63
< sniff sniff sniff > cough cough, hey whats going on?
Old Aug 19, 2001 | 05:11 PM
lexguynj's Avatar
lexguynj
That's called a Dr. squeezing your ***** during a physical examination! YIKES!
Old Aug 19, 2001 | 06:07 PM
D-MAN63's Avatar
D-MAN63
HAHHAH LOL
