Got my Borlas
Old Aug 23, 2001 | 10:56 PM
  #31
Brian S's Avatar
Brian S
I still have the CF on. I'm still waiting for the replacement SS to come. .
To The Bolt People,
You don't need new bolts. Only the nut is welded, and it's welded to the flange you don't replace. Unscrew the bolts, replace exhaust, screw back in.
I did get new gaskets at $8.00/each. I didn't replace them when I put on the CF Borlas, so I figured now would be a good time to put some new ones on.
Brian
Old Aug 24, 2001 | 06:28 AM
  #32
HDDuece's Avatar
HDDuece
The nuts are not attached to the Borla muffler flange like they are on the stock mufflers. You need to buy new nuts unless you want to cut the old ones off with a torch.
Old Aug 24, 2001 | 08:46 AM
  #33
dominick's Avatar
dominick
Originally posted by HDDuece
The nuts you need are M10-1.25. They are metric and try to get hardened. If you pick these up ahead of time it makes the job go a lot smoother.
hddeuce how in the world did you get the spec on these bolts? i'm impressed.
my matsci guru wanted me to confirm with you that it's actually 1.25 and not 1.5 or some other more common thread rate. apparently 1.25's are rare but could have been designed for this application. just checking.
also, did you pick these up at the dealer? kragen?
thanks.
Old Aug 24, 2001 | 11:26 AM
  #34
HDDuece's Avatar
HDDuece
Picked up the nuts at Auto Zone. That was the number on the package they came in.
Old Aug 25, 2001 | 11:11 AM
  #35
Brian S's Avatar
Brian S
Whoops, my bad. Bad memory, that is. I just looked at the stock mufflers and my '99 is no different. The welded nuts are on the stock mufflers, not the still on the car. Midas put a new set bolts on when they did my CFs.
Brian
Old Aug 31, 2001 | 06:41 PM
  #36
tancuan82's Avatar
tancuan82
Default Okay, need help
I just called lexus and they said that the bolt was not welded in and that i can use it again. but i am not sure about that. does anyone know the size and the lenght of the bolts? and what they are called. i don't know how to describe it to the auto shop. thanx
Alex
Old Sep 1, 2001 | 08:23 AM
  #37
HDDuece's Avatar
HDDuece
The bolt is not welded to the flange. The nut is welded to the flange. You can reuse the bolt but not the nut.
Old Sep 18, 2001 | 02:45 PM
  #38
Brian S's Avatar
Brian S
Exclamation Update!
Update!
Long story, but I got a call back from a rep at Borla. He was patient and I went through this and another post on the phone to compare the difference between the tips. He had a hard time telling, but did say he could that the new tips were rounder and "ended in less of a point" at the edges. He is still not sure whether this was a factor of production changes, or individual variation in manufacturing. I'm hoping it was a manufacturing snafu and a new tip technique has been employed. In any case, he's going to compare the pictures to the new exhaust he has waiting for me. He'll mail the suckers to me and I'll choose which ones are best looking. Let's hope for some rounder exhausts!
Brian
newyorksc
Jun 22, 2005 05:36 PM
chuckb
Mar 8, 2005 02:01 PM
Brian S
Sep 26, 2001 09:29 AM
Brian S
Jun 27, 2001 08:33 AM
