Need Help Removing Lighter Compartment
Old Jan 16, 2006 | 02:48 PM
Lexizm's Avatar
Lexizm
Default Need Help Removing Lighter Compartment
Has anyone ever removed the cigerette lighter section under the radio before? I've heard of some people putting their SAFC in the lighter compartment and that's where I want put mine. Do I need to dremel that area out or is there away to remove it? I'm thinking that it can be removed because there is a light there and I'm sure it can be replaced if it goes out.
Does anyone know how to do this? Any help is appreciated, thanks.
Old Jan 16, 2006 | 03:05 PM
PHML's Avatar
PHML
Master Thread Closer!!
Just pull it out....its held in there by clips.
Old Jan 16, 2006 | 05:08 PM
DetMich1's Avatar
DetMich1
Open the door to the compartment. Reach in under the upper edge with both hands in supinated (palms up) position. Pull out and up , about 30 degree angle I would say. Once clear of dash disconnect the electrcal for the light and the lighter. If you have the ashtray unit with the OEM wood veneer and plan on installing something else in that spot, consider selling the ashtray as it fits into the 98-2000 models as well. Should be worth about $150-175 if in good condition.
Old Jan 16, 2006 | 06:14 PM
GSoup's Avatar
GSoup
CL Folding 10,000
yup..just pops right out ... put the car in nuetral and just like detmich instructed....
Old Jan 16, 2006 | 06:27 PM
lexusondubs's Avatar
lexusondubs
dubsonlexus
yes i was curious about this also iam considering installing sirus in the ashtray does anybody have a spare ashtray ??
Old Jan 16, 2006 | 06:45 PM
Lexizm's Avatar
Lexizm
Thanks for the info, it just came right out just like you said. I was actually talking about where the actual lighter socket is housed. I was able to get the lighter socket out from the rear, but I had to remove the support that held the lighter socket and remove th screws so it comes apart.
The SAFC fits right in; now it looks like the ash tray holder is holding the SAFC unit. Thanks again guys.
Old Jan 16, 2006 | 06:48 PM
Chpsk8's Avatar
Chpsk8
Just so you know, the entire thing pulls out including the wood surround. Put the car in nuetral, open the ashtray. Grab both sides of it and rock it bakc and forth left to right pulling back. There are four friction clips that are holding the entire assembly in place. It's a straight back motion, then lift it to clear the shifter. Pretty simple. It threw me off when I saw the entire assembly including the woodgrain panel come with it.
I removed mine to dremmel out a little groove under it to run my sat. wires. My Roady XT was a touch too large to fit in the ashtray, so I mounted it right in front of it. I don't smoke so it didn't matter that I have to move the Roady to get to the ashtray.
Old Jan 16, 2006 | 07:08 PM
lexusondubs
dubsonlexus
any pics of the removal and install?? sorry LEXISM dont mean to thread jack let me know and ill delete
Old Jan 17, 2006 | 12:07 AM
DetMich1's Avatar
DetMich1
I have a spare ashtray but its the black version from pre-2001 not the wood grain that was introduced in 2001+. If you're interested PM me.
brandoe91
Apr 21, 2010 03:21 PM
chuckb
Nov 13, 2004 12:59 PM
SilverBolt 219
Jun 1, 2002 01:16 PM
