Hey guys, i searched and found a way to access the menu of my navigation system. I tried it but that's not what i'm looking for.
I remember reading once about a way to allow you to type addresses, etc... while the car is moving. Anyone know how to do it?
rominl
exclusive matchup
close
- Join DateMay 2002
- LocationLovely OC
iTrader Positive Feedback100
iTrader Feedback Score(4)
Liked:475 Times in 345 Posts
if you have 2002, try this:
menu button
system button
touch top left, bottom left, too left, bottom left, and then bottom right
see if it works
so far i know of 3 ways to get to the screen for different yrs dvd nav
everyone else, PLEASE be VERY CAREFUL. it's the manufacture setup screen, mess up the settings and you get youself in trouble
menu button
system button
see if it works
The navigation works while the car is in motion (obviously), but it does not allow you to input POI's, addresses, calendar info, etc.... I will try this tomorrow to see if it works.
yes I know Navigation works while in motion!!! anyways it also lets you punch in address while the car is in motion when the override is used. I believe it resets eveytime the car is turned off though... so basically you have to enable the override everytime you get into the car.
Quote:
For real? I hope not - that can get really annoyong.Originally Posted by Insomnia
Quote:
If you are refering to the reset, it is true. You have to do the procedure each time you start the car.Originally Posted by aliti19
Where is the system button? Does it come up on the screen somewhere?
Quote:
menu button
system button
see if it works
Originally Posted by rominl
if you have 2002, try this:menu button
system button
see if it works
Quote:
Maybe one of these other options:Originally Posted by aliti19
https://www.clublexus.com/forums/sho...d.php?t=181707
What options do you see when you hit the nav "menu" button?
This seems like it should work, i'll try it tomorrow:
Thanks for the link!
Press Menu button on right side of Nav Screen
On this Menu Screen screen, it includes the "Suspend Guidance button, etc."
In the top right corner there is a DVD button
Press the DVD button which takes you to the DVD Information menu which tells you what DVD version is installed in your car
On this screen, press the touch activated screen as follows:
1. Top Left
2. Bottom Left
3. Top Left
4. Bottom Left
5. Bottom Right
The Service Menu will appear. Press and hold the "Override" button until you hear a beep and the button is highlighted. This is allow you to enter addresses, POI, etc. on the Nav system while the car is in motion. You must re-do this each time you restart the car and you can do it while the car is in motion so it can be helpful when your passanger can override the system and enter addresses for you on the go.
1. Top Left
2. Bottom Left
3. Top Left
4. Bottom Left
5. Bottom Right
rominl
exclusive matchup
close
- Join DateMay 2002
- LocationLovely OC
there are 2 different procedures for different yrs.
GS
one for 01 and 02
one for 03 to 05
there is a 3rd way, but that's for 4th gen nav on cars with bluetooth
GS
one for 01 and 02
one for 03 to 05
Damn, that override didn't work. I held it until it was highlighted, but when i exited the screen I still couldn't put in addresses.
rominl
exclusive matchup
close
- Join DateMay 2002
- LocationLovely OC
you must be missing something man. i just did it on a 01 gs this past weekend
Nevermind! I just did it a couple hours ago. I figured out what i was doing wrong...
After I held the override button down and it beeped, i would exit the screen by pushing the menu button. When i exited using the BACK button, it worked! Thanks guys!
