Plastic Door Trim Problem
Old Sep 19, 2005 | 06:03 PM
  #31
ARISTO*7's Avatar
ARISTO*7
Originally Posted by Benjamin T
ne1 have luck with these part numbers? i tried using them on the park place lexus order website and the numbers are invalid
the part # for my driver side door in alpine silver was 75736-30170-BO
Old Sep 19, 2005 | 07:27 PM
  #32
Benjamin T's Avatar
Benjamin T
that number worked! thanks
Old Oct 3, 2005 | 10:05 AM
  #33
ted920's Avatar
ted920
Is there a DIY on how to do this or does anyone have good instructions on how to replace and install the new trim piece?
thanks.
T
Old Oct 3, 2005 | 10:27 AM
  #34
Benjamin T's Avatar
Benjamin T
somewhere up top someone explained it very accurately how to do it... in my case my car was repainted at some point in it's life and a shop used double sided tape for some reason and had me going
Old Oct 3, 2005 | 11:07 AM
  #35
GSXLEX's Avatar
GSXLEX
Just did mine today.Picked up the part from the local dealersiphon and they quoted me $150 to install it.. Took about 30 minutes to do and thats because Im prolly super **** about stuff..Anyway heres my technique just to recap for this page...
1.Open door and find 3 plastic 10mm bolts.(2 at rear of door 1 at front) and remove them
2.From the bottom,seperate just enough to get to 5 philipps screws and undo
3.Pull the trim down and off.
INSTALL
The tricky part(and most time consuming for me)is woorking the new trim back on.
The dealer removes the whole plastic panel as you will see a starter slot near the front.You can manuever it on there,I didnt(****)cause I figured this peice is already fragile but it can be done with no damage..Once the new trim is on reverse the process and ENJOY!!!
Old Oct 19, 2005 | 09:42 PM
  #36
JVProGS400's Avatar
JVProGS400
Lightbulb Part numbers for lower door trim (99 GS400 / Blk)
Here is a scan of the labels for the lower door trim in the gallery:
https://www.clublexus.com/gallery/da...TrimLabels.jpg
It took me about 45 minutes to replace both front door mouldings(as stated above I went the external route, thanks for the tip) Make sure you have either a short stubby philiips screwdriver or one of those "S" type short screwdrivers. The screw at the front of the door is hard to get to.
Good luck!
Old Oct 20, 2005 | 10:35 PM
  #37
Shogun's Avatar
Shogun
Default Superglue
Ummm, I superglued it back and all has been well for the last 20K miles.
Eric
Old Oct 21, 2005 | 11:08 AM
  #38
dwoods420's Avatar
dwoods420
Hello,
I just bought a set ot four for my car from Carson Toyota. $82.50 shipped for all four pcs. My lexus dealer quoted me $125.00 for 1 pc plus install.
I really only needed both pass.sides. Installed both in a half hour. It was easy.
Old Jul 27, 2006 | 01:46 PM
  #39
Benjamin T's Avatar
Benjamin T
just bringing this back from the dead....
the part number above is no longer valid for the front doors in alpine silver. it is now 75736-30172-B0 and 75735-30172-B0... $25.67 each from sewell lexus (thanks darrel!).
Old Jul 27, 2006 | 04:04 PM
  #40
e-man's Avatar
e-man
One of mine separated over the weekend. I super-glued it, but it looks like crap. I think I'll order one of these tomorrow. For all of you who have silver cars, was there any issue with the color matching? I have to believe that my car is not the exact same color it was 7 years ago due to fading.
Old Jul 28, 2006 | 10:58 AM
  #41
ZinikGS's Avatar
ZinikGS
I had the same problem on the passenger side. Put some 3m double sided tape as a temporary fix, planned to go back and use some JB weld epoxy. The tape has held up fine so I haven't epoxied.
Old Jul 28, 2006 | 11:01 AM
  #42
Benjamin T's Avatar
Benjamin T
my car was repsrayed 2 years ago (also a 99), and the trim does match the new paint on the car.
i wish they had painted both sides of the trim because the overspray on the backside is a little unsightly... but then again who looks under the door?
Old Sep 26, 2006 | 03:43 PM
  #43
chinkster's Avatar
chinkster
what is the part numbers for all 4 doors?
75735A front passenger Door bottom molding
75736A Driver's Door bottom molding
should i assume 75737A and 75738A for the rear doors?
Old Sep 28, 2006 | 10:01 AM
  #44
thaimonkee's Avatar
thaimonkee
where is everyone getting these moldings for 25 dollars?
lexus of rockville and silverspring are charging 45 each.
l-tunedpartsshould have these at a good price right?
Old Sep 29, 2006 | 01:59 AM
  #45
chinkster's Avatar
chinkster
someone post the link to those bottom moldings!! i really wanna buy them!!
