HELP!!! I think I got the wrong part...
So, here I am with this question again. I just got what supposedly is l-tuned ECU from Carson Toyota (www.l-tunedparts.com). First, their instructions state it's so easy to remove the stock one - just remove two screws and snap off the clip, take off the bottom panel and you are done. Stock steering ECU is right there, just remove the nut holding the bracket. Yeah right.
Not sure about other year / models, but on my 99 GS300 it was impossible to get to the stock one this way. I had to almost remove the whole steering column and surroundings.
Anyway, I managed to remove the stock steering ECU, and there comes my disappointment. I put the stock one and "l-tuned" next to each other, and they are totaly the same. All the engraved letters and numbers on one side totally match.
The only numbers that are different are the ones stamped that you can barelly see on the other side. My stock one reads "10T 6 A78" and the l-tuned one reads "6D 6 A199" The box that l-tuned came in doesn't have any l-tuned indication either. So, can anyone tell if the stamped numbers is the only difference, or should engraved ones be also different?
Thank you.
As for the install, I have a 98 and did not have to do anything with the steering column.
Barring that, you have to drive around and FEEL the difference (very subjective). I did other suspension changes so never could do apples to apples comparison.
Trust in the seller. I bough mine through SteveGanz and I trust him.
We need to do our part by marking the non-Ltuned and essuring they do not get into the market stream.
Salim
and the setup is the same for all yrs, from 98 to 05. it was pretty easy to change out, at least i my case
You're just going to have to trust that the one that was sent is a genuine L-Tuned ECU. Again, they look exactly the same and you'll just have to feel the difference. You might feel it, and you might not.....that's been discussed at length as well.
But I have to tell you guys, as for the feeling - I don't feel ANY difference from the stock one on ANY speed whatsoever
. Makes me think that Lexus stock steering ECU is already great by default. So, IMO it was a waste of $140 for this mod. First time I regret about some mod...
Was much easier than removing the original. Just an FYI to others.
