How to remove ignition panel
Old Feb 27, 2005 | 06:02 PM
Celsior Master's Avatar
Celsior Master
Default How to remove ignition panel
I'm trying to remove the ignition panel on my 2nd get GS so i can replace the green light with a led. Does anyone know how the top of the panel is attached? I pryed off bottom part with a screwdriver but the top won't move that easily. Do i just have to pull on the panel from the bottom part that i popped out? I did this on my LS but it was a lot easier and the whole panel came off after i pried from the bottom.
Old Feb 27, 2005 | 06:04 PM
PHML's Avatar
PHML
Master Thread Closer!!
Hey bro...
Here it is....
https://www.clublexus.com/forums/sho...light=ignition
Pete
Old Feb 27, 2005 | 06:39 PM
Celsior Master
hey thanks pete. thats what i was searching for all this time.
Thanks also for the footwell thread. That helped me a lot last year when i was working on my LS
Old Feb 27, 2005 | 06:49 PM
jonathancl's Avatar
jonathancl
When you remove it, be careful with the felt on the left side.
It's only attached with glue, and mine came off when I installed my remote starter.
Old Feb 28, 2005 | 01:50 AM
rominl's Avatar
rominl
exclusive matchup
mine too, fell off. though i am not sure how useful that thing is?
Old Feb 28, 2005 | 03:59 AM
jtanoyo1's Avatar
jtanoyo1
I just yanked mine off....nothing like a little force to make it work haha.
Old Feb 28, 2005 | 07:05 AM
LEXUS_KID's Avatar
LEXUS_KID
Originally Posted by PHML
Pete nicely put can't get any easier.
Old Mar 1, 2005 | 06:10 PM
Celsior Master
just finished replacing the ignition light with a led. not as easy as i thought tho! the top part of the cover takes some serious force to remove. and i had to use a dremel to shorten the led so it would fit. then putting the led's harness back into the plastic ring thing was pretty tough cuz the harness wire is just barely long enough. it wasn't long enough so i could hook up the light harness to the plastic ring thing first and then put the ring back around the ignition. but the results are great!
Old Mar 1, 2005 | 08:39 PM
rominl's Avatar
rominl
exclusive matchup
wow man, you gotta work on your car more j/k
the led fits very tight indeed, but i didn't have to cut anything though, that's weird. and yes the wire is very tight, but some jiggling got me going fine
sjowett
RX - 3rd Gen (2010-2015)
18
Oct 10, 2019 04:39 PM
DerekGordo
Feb 25, 2017 08:45 AM
MjThind
Sep 7, 2013 07:33 PM
norman52
Nov 19, 2011 03:51 PM
wizard51
Nov 14, 2009 03:08 PM
