Car pulls to the right
Old Aug 27, 2004 | 07:54 PM
e-man's Avatar
e-man
Default Car pulls to the right
Hey guys. I've owned my 98 GS400 for about 6 months now, and ever since I bought it, it has pulled to the right ever so slightly. I've got the stock 17" rims, but am planning on switching to the stock 16s for the winter. I was thinking of taking it in to get an alignment, but before I do that, I wanted to get your opinion. Could it be the tires that are causing the pulling? How about a wheel out of balance? Assuming it is an alignment issue, how does a car get out of alignment? Is it common? What does everyone think? Thanks.
e-mab
Old Aug 27, 2004 | 10:24 PM
lexusondubs's Avatar
lexusondubs
dubsonlexus
Default Re: Car pulls to the right
e-mab
i would say its the alignment yes it it a common thing your car can get knocked out of alignment several different ways but the most common way it to hit a pothole
Old Aug 28, 2004 | 08:39 AM
corkycal's Avatar
corkycal
your tires may make your car pull either right or left. the best was to rule out the tires is swop them around and see if your car pulls after the swop.
first thing i would do is swop the front to the rear and drive around. if you can't get an answer, put on the 16" and drive around.
if you don't have anytime, just go to your alignment guy.
Old Aug 28, 2004 | 12:19 PM
e-man's Avatar
e-man
Corkycal -- I think that's good advice. The easiest way to check would be to do the front to back swap, although I don't own a jack stand, so I would have to take it somewhere to have it done. My guess is that it's an alignment issue. I'll figure it out first thing next week. Thanks.
e-man
Old Aug 28, 2004 | 09:21 PM
corkycal's Avatar
corkycal
let us know if the problem was fixed
Old Aug 30, 2004 | 01:26 AM
rominl's Avatar
rominl
exclusive matchup
yeah swapping wheels could give you a good idea, but i guess an aignment would be able to help you determins a lot too
Old Aug 30, 2004 | 08:39 PM
e-man's Avatar
e-man
Default UPDATE
Well, I took the car in today and asked Lexus to rotate the tires, front to back and back to front. The head mechanic asked why and I explained the pulling problem. He first took a look at the front tires and noticed that the front left tire was wearing a little unevenly, probably as a result of taking too many right-handed cloverleafs too fast. Anyway, they rotated the tires, and as soon as I got in the car, I immediately knew that the problem was solved. I am no longer fighting with the car to make it go straight. I can't believe I've been driving with it like this for the past months (that's how long I've owned the car). Moreover, I'm not sure why, but the car all of a sudden rides much nicer, softer, quieter, etc. That's probably my imagination to some extent, or maybe the rear tires had more tread on them. Whichever the case, I couldn't be happier. If anyone has a pulling problem, try rotating the tires first as a cheap alternative to having an alignment. It just might work.
And, it's a good thing that I didn't need an alignment. The mechanic told me that their parts guy backed up his pick-up truck into the alignment machine the other day and really messed it up. To quote him, "the alignment machine now needs an alignment." Too funny.
e-man
Old Aug 30, 2004 | 11:11 PM
rominl's Avatar
rominl
exclusive matchup
i guess you just have to start rotating the tires more then huh
Napalvr
Jun 8, 2015 06:35 PM
BlueES
12
Dec 28, 2011 08:26 AM
virtualinsanity
Suspension and Brakes
Jun 10, 2002 09:37 AM
