Steering problem
Old Feb 19, 2004 | 07:06 AM
Navaz's Avatar
Navaz
Default Steering problem
I have a problem with my steering and it's driving me crazy. Intermitently my steering will feel very hard to turn almost as if there is no power assist, I was wondering if anyone eles has ever had this problem and what fixed it. Thanks in advance.
Old Feb 19, 2004 | 09:21 AM
PHML's Avatar
PHML
Master Thread Closer!!
I would reset the ECU and check your power steering fluid and its respective hoses.....if that don't work....take it to the dealership.
Pete
Old Feb 19, 2004 | 11:42 AM
Navaz's Avatar
Navaz
I forgot to mention that I have had this problem for the past 2.5 years, At first the lexus delership could not duplicate the problem as it is intermitent. Now however they felt it and tell me that I need a new steering rack. I just wanted to know from those who have had this problem what they did because I dont want to spend $1500 CND for a new rack with no positive results.
Old Feb 19, 2004 | 12:01 PM
JPI Racing's Avatar
JPI Racing
High speed? Low speed?
JPI
Old Feb 19, 2004 | 01:29 PM
rominl's Avatar
rominl
exclusive matchup
they must have records of that before the warranty went away. insist on having it fixed under warranty, coz' it's not your problem, it's their problem for NOT finding out the problem
Old Feb 20, 2004 | 12:24 PM
mmarshall's Avatar
Default steering problem
Before the rack is replaced....an expensive and major job.....check and see if the power steering fan belt is slipping. Maybe all it needs is a new or tightened belt....if it is slipping, that would account for the alternating hard-soft feel of the steering.
Old Feb 20, 2004 | 12:32 PM
JPI Racing's Avatar
JPI Racing
Default Re: steering problem
There is a VSV(vaccum switching valve) on the pump that will effect your power steering pump.
JPI
Old Feb 20, 2004 | 06:07 PM
gserep1's Avatar
gserep1
Default DON'T FORGET THE POWER STEERING FLUID
Hello,
I know this sounds redundant, but check the condition of the fluid, and flush the entire system 2 or 3 times with fresh fluid to get out the old stuff. It takes automatic transmission fluid (Dexron). I used AMSOIL UNIVERSAL AUTOMATIC TRANSMISSION FLUID, and it works great. I did not have problems before the change, but the fluid was terrible looking.
I removed the driver's front wheel after putting it on a rack. There is a rubber hose coming from the power steering pump that is visible on the power steering rack. Remove that rubber hose, and place a pan under the car. Move the entire wheel assembly front and back until most of the fluid comes out. This drains the reservoir and the rack and pinion assembly. Re-install the hose, refill the reservoir, start the engine and let run for a while, and then repeat the procedure until the fluid comes out clean. However, if your rack and pinion assembly is leaking fluid anywhere, (like at the ends of the cylinder ram) , it may already be too late to do this.
Hopefully this will help somewhat, or completely solve your problem.
RX400BGO
Nov 21, 2019 08:41 PM
obakemono
Oct 10, 2018 12:24 AM
nclexus04
May 10, 2010 06:25 PM
leeanders
Maintenance
Jan 2, 2006 02:13 PM
