New owner need help: 03 GS300 Fuel Pump Module Assuembly
Old Dec 2, 2023 | 06:47 PM
donnieb83's Avatar
donnieb83
Default New owner need help: 03 GS300 Fuel Pump Module Assuembly
Hello everyone, I just picked up a 2003 GS300. I put my first full tank of gas and noticed that it was leaking under the driver's side rear tire. I pulled the rear seat and pulled the entire fuel pump module assembly and discovered the plastic "top hat" (unsure of the name) portion of the entire fuel pump module assembly is broken. With it being degraded/broken, it's unable to make a good seal and fuel is leaking under my car. There was a Toyota part # 77020-30011 that I found on it. I called Toyota and Lexus and they do not have it. Where can I buy the just the "top hat" or the entire fuel pump module assembly? Below are a couple pictures where I highlighted the problem areas in red.
Old Dec 3, 2023 | 03:27 AM
DundukovEM's Avatar
DundukovEM
Try these part numbers from your parts dealer:
Lexus 77024-30040 -
Plate Sub-Assy, Fuel Suction
Lexus 77169-33020 - Gasket, Fuel Suction Tube Set
Old Dec 3, 2023 | 06:02 PM
donnieb83's Avatar
donnieb83
Lexus 77024-30040 -
Thank you so much! These are the exact parts I was searching tirelessly for. I was getting nervous that the top portion was an obsolete part, and I nearly purchased a used one that I found online. I just placed my order to fix my GS300!
Moos0004
GS F (2016-present)
15
Apr 10, 2026 07:29 AM
Lexusgs3002jz
Nov 14, 2023 05:58 AM
PEPSI
Sep 17, 2021 11:47 AM
burny
Jul 20, 2016 01:59 PM
braheem
Mar 5, 2004 09:01 PM
