Battery
Old Sep 19, 2023 | 10:58 PM
Repacent's Avatar
Repacent
4th Gear
Default Battery
My battery isn't getting a charge from alternator I can use a jump box to start car and everything works as normal and as soon as I shut it off no power anywhere does anyone know what the issue is if so please help
Old Sep 19, 2023 | 11:48 PM
firelizard's Avatar
firelizard
Consider replacing the alternator, or having it tested.
Old Sep 20, 2023 | 12:26 AM
Repacent's Avatar
Repacent
4th Gear
I have checked the alternator is good
Old Sep 20, 2023 | 12:37 AM
Repacent's Avatar
Repacent
4th Gear
I have checked alternator
Old Sep 20, 2023 | 10:22 AM
KTGS300's Avatar
KTGS300
Have you checked if the battery is holding a charge?
Old Sep 22, 2023 | 08:48 PM
Repacent's Avatar
Repacent
4th Gear
Yes I've tried a different battery I can use a jump box to start and everything will work as normal but as soon as I turn it off no power anywhere it started when I put in the radio fuse it also made my blower motor stop working so I pulled the radio fuse back out and blower motor works but battery won't charge is there a fusible link in between alternator and battery or relay ,fuse
Old Sep 24, 2023 | 07:01 PM
DundukovEM's Avatar
DundukovEM
Of course, there are fuses between the alternator and the battery. Right next to the battery in the engine room No. 1 Relay / Fuse Box.
Engine Room No.1 Relay / Fuse Box
jdanielca
May 7, 2025 04:00 PM
coolmanees
Jan 22, 2021 05:38 PM
ATLs400
Aug 22, 2020 10:59 AM
SOLEdier
Jun 16, 2010 04:11 PM
Cannonbear
Jun 17, 2005 05:03 PM
