Jacking height to remove transmission
Old Mar 11, 2023 | 12:05 PM
Tuhrak's Avatar
Tuhrak
Default Jacking height to remove transmission
Hello,
I have a 2004 Lexus GS 300. I need to remove the transmission. What is the minimum height the car needs to be raised to (in inches) so that the transmission can be slid out from the side on a jack?
For reference my jack stands rise to a maximum height of 15.4 inches, and the transmission jack is at 8 inches when fully lowered. Will these be enough?
Old Mar 12, 2023 | 02:29 PM
Raven01750's Avatar
Raven01750
This should have everything you need. Have fun...😁
Paul
File Type: pdf
Old Mar 12, 2023 | 03:00 PM
Tuhrak's Avatar
Tuhrak
This pdf just seems to have specs, not really what I was looking for…
Old Mar 12, 2023 | 04:55 PM
Raven01750's Avatar
Raven01750
It has dimensions doesn't it? You cant extrapolate the additional height of a transmission jack or whatever means you plan on using to drop it?
If you are looking for someone to tell you that the bottom of the car needs to have this much clearance from the floor so you can bring it down safely doesn't exhist because no one knows what you are using to secure and lower the transmission with.
You haven't gotten any other answer because of that. So, use the dimensions of the transmission and tool height added together would be my only answer. Good luck. Stay safe. Not worth getting injured over no matter what you use.
Paul
Old Mar 12, 2023 | 05:09 PM
Tuhrak's Avatar
Tuhrak
I literally specified in my original post what I was using to lower the transmission, a transmission jack and also its dimensions. And to your other point, no the PDF does not have any useful information (for me in this scenario) which is what I politely said in my reply to the first post.
If you don’t have the answer, that’s totally fine. I can muddle along on my own, but I believe in doing the easy thing first and simply asking if anyone has this info. If someone does, it helps me and also anyone else who might need this info.
Anyways, thanks
Old Mar 12, 2023 | 05:22 PM
Gerf's Avatar
Gerf
Old Mar 12, 2023 | 05:33 PM
Raven01750's Avatar
Raven01750
Anyways, thanks
I tried at least. 😁
Paul
Old Mar 12, 2023 | 06:17 PM
Raven01750's Avatar
Raven01750
Theres another more generic video that states the bottom should be 20-24". Don't know if that applies to your situation. Just trying to help. The title is "How to Replace a Transmission (Full DIY Guide) by ChrisFix.
Paul
Old Mar 12, 2023 | 07:27 PM
Tuhrak's Avatar
Tuhrak
Appreciate it, thanks for the responses and I will
Check the videos out.
leg3ndary
Oct 18, 2017 12:41 PM
LS400_96
Feb 28, 2009 10:19 PM
