Aristo water pump conversion
Old Oct 31, 2019 | 11:32 AM
Firstang01's Avatar
Firstang01
Default Aristo water pump conversion
Hello friends,
I have a 1993 aristo. And I am in confusion as to what water pump to use.
1. Original Water pump has line going to hydro fan. And finding this pump is becoming a PIA
2. I can do a USDM conversion. In this case what is the pump assembly i should be using and what will replace the existing fan? Just so you k now I am located in Phoenix, AZ. So it get really hot in summers. So I do not want to compromise on cooling system.
I will greatly appreciate any insight, help and instructions on this topic.
Thanks in advance!!
Old Oct 31, 2019 | 01:28 PM
RyanV9's Avatar
RyanV9
I swapped for the USDM pump on a car I had before. I opted to go with a Supra radiator and electric fans as well which required slight medication for the upper rad supports and relocation of the bottom rad supports. I was doing a manual conversion at the time, so I didn't need a trans cooler, but if you go this way with an auto, you'll also need to buy a remote oil cooler for the trans.
Depending on what the issue is with your current pump, I know some people have chosen to just change the impeller plate and gasket. I think I have two sitting on the shelf in case I need them in my current Aristo.
Old Oct 31, 2019 | 01:46 PM
Firstang01's Avatar
Firstang01
Thank you Ryan!
At moment no issues with the car. Just want to do the maintenance and go from there. How did you wire the electric fans? Do u have a writeup or a build thread that i can refer back to? Also any idea what the part# would be for the new conversion pump?
Old Oct 31, 2019 | 03:07 PM
RyanV9's Avatar
RyanV9
Unfortunately, no, I don't really have a build thread (at least not on this forum), and I didn't do the work myself, so I couldn't tell you how it got wired up.
I don't have the part number handy, but it should be easy to look up because you just need to find the part number for the whole water pump assembly (front and back).
Old Oct 31, 2019 | 03:25 PM
Firstang01's Avatar
Firstang01
Thank you Ryan!
Old Oct 31, 2019 | 06:44 PM
joewitafro's Avatar
joewitafro
Realized I gave you the wrong water pump part number before. Here's the TT USDM water pump front/rear: 16100-49847
You will also need a clutch fan setup, which can be a sc300/gs300/1jz/supra.That would give you the most reliable OEM fan setup, and allow you to get rid of your entire hydro setup and avoid the electric fan wiring.
Old Oct 31, 2019 | 08:01 PM
Firstang01's Avatar
Firstang01
I appreciate it Joe. Can i pick fan setup from any gen gs,sc300?
Old Oct 31, 2019 | 09:27 PM
joewitafro's Avatar
joewitafro
Yeah im pretty sure even is300 would work (assuming its not electric), and as long as its a 2jzge/2jzgte/1jzgte. Its a 4 bolt snout housing. I've used a fan off a 1st gen gs300 and 1jzgte.
m1k3yg
Jul 11, 2012 02:35 AM
tonysc400
Jun 1, 2009 08:53 AM
sorka
Jul 26, 2008 11:47 PM
ethan_phan
May 20, 2007 11:09 PM
