Headlight aim...
Old May 26, 2003 | 05:32 PM
Wald GS's Avatar
Wald GS
O.C. Lucky Strike Fanatic
Default Headlight aim...
Hey guys,
My driver side headlight can be adjusted up and down, but cannot move left to right. It is basically aimed at the right side. No matter how many times it is adjusted (turning the adjuster), it doesn't move. Apparently something is stripped and therefore is not allowing it to move. What can I do?
Thanks
Bryan
Old May 26, 2003 | 09:33 PM
siniquezu's Avatar
siniquezu
I noticed I have the same problem with my vertical alignment. I keep turning the hex screw but no change. Any help anyone?
Old May 27, 2003 | 02:38 PM
Wald GS's Avatar
Wald GS
I just realized that since my aim on the right is ok. I can just aim the Right to the LEFT to compensate. Basically as a result of the Left aiming to the Right already. What do you guys think?
Old May 29, 2003 | 09:03 PM
C to the O's Avatar
C to the O
whoa.... i didn't realize we can adjust our lights up and down, i thought we could only do it left to right. (thank goodness for CL ). I know there are two screws where the headlight assembly is. One of them moves the light from left to right, so by process of elimination, the other should move it up and down??? mine doesn't up or down at all.. am i missing something?
Old May 29, 2003 | 09:52 PM
C to the O's Avatar
C to the O
Old May 29, 2003 | 10:14 PM
Wald GS's Avatar
Wald GS
I'm happy!! I made my lights low now and I am not blinding anyone. haha.
The outer scew on the top of the headlight, regardless of whether its driver or passenger side moves the light left and right. Clock wise turn of the screw moves it to the RIGHT, COunterclockwise moves it to the LEFT.
To aim the light up and down its the silver colored long metal piece behind the light. To adjust the aim up, turn the screw clockwise, and to move it down turn it counter...
Old May 29, 2003 | 10:18 PM
Wald GS's Avatar
Wald GS
In my case, my driver side aim is to the right. I cannot adjust it to the left. This is probably the result from the fender bender before I bought the car...Oh well, thats life!
Old May 30, 2003 | 12:48 AM
Jmai22's Avatar
Jmai22
DUDE. you typed it wrong Bryan.
The outer screw on top moves in left and right. Clock=right, counter clock=left.
the inner screw does nothing but move this little meter for future reference. don't even bother it doesn't move the light at all.
The screw on the BACK of the headlight moves the headlight up and down. its a long 8mm nut that sticks out the back of the housing. Clock=up, counter clock=down
Old May 30, 2003 | 12:57 AM
Wald GS's Avatar
Wald GS
Nothings wrong, what are you taking about Jonnnny?
Old May 30, 2003 | 01:00 AM
Jmai22's Avatar
Jmai22
Old Jun 1, 2003 | 04:00 AM
C to the O's Avatar
C to the O
YES!!! i've finally adjusted my beams the way i've wanted them. I'd had a fender bender before, and the aim has been off ever since...
good times...
JohnnyCake
May 5, 2023 06:09 PM
supralative
Nov 5, 2012 06:27 PM
nsxiboi
Mar 15, 2009 06:53 AM
Yahoo27
May 26, 2008 06:01 AM
100mgbluep
Feb 9, 2008 08:22 PM
