Downstream o2 sensor
Old Feb 26, 2016 | 02:02 PM
Slickcam's Avatar
Slickcam
Default Downstream o2 sensor
How do I get this out? Do I just pull that rubber seal out?
Just trying not to break anything
Old Feb 27, 2016 | 03:24 AM
TRACKMKIII's Avatar
TRACKMKIII
Disconnect the connector inside the car then pull the rubber grommet out and pull connector through the hole.
Old Feb 27, 2016 | 03:55 AM
Slickcam's Avatar
Slickcam
Damn. Is it under the seat? Or am I pulling the carpet all the way back
Old Feb 29, 2016 | 05:37 AM
1fast2jz's Avatar
1fast2jz
pull carpet from under passenger side. remove bottom cover from glove box. after you pull carpet you will see a black cover that where the ecu is located and you will find the plug to o2 sensor below ecu and harness.
hooterbif
Jul 23, 2014 06:23 AM
dakeypoo
Jul 14, 2012 02:26 PM
Avarec
IS - 1st Gen (2001-2005)
Feb 19, 2011 06:51 AM
BostonSC4
May 18, 2010 04:00 PM
