HELP important question about ecu's
I was looking on alldata at school today at the ecu pin outs and I found some info and I just want to confirm it with some of you because sometimes alldata is wrong.
I found that In the GS E7 A plug there is no kickdown in the 3 pin, sub heated o2 sensor in pin 30, sub heated o2 sensor in pin 36 nothing is in this on the SC ecu.
On the gs E8 pin A/T No. 4 solenoid is pin 14, A/T No. 3 solenoid is pin 14
On GS E8 pin 21 O/D direct clutch speed sensor, VSV intake air control valve pin 39, main heated o2 sensor rear pin 72, main heated o2 sensor front pin 73
The SC doesn't have these pins in this sockets
On the sc E8(E14) pin 1 has O/D direct clutch speed sensor, A/T No. 3 solenoid,
SC E8(E12) sub heated o2 sensor pin 61, sub heated o2 sensor pin 71,
GS doesn't have these pins in these sockets
I was told by someone on here that said he has had no probs swapping the ecu's but my concern is the heated o2 sensor wiring I could give a damn about the auto stuff since my car is already r154 swapped (btw this is in concern to me because it's for my 2jz swap in my 90 cressida)
Billnoelr
Apr 21, 2019 04:37 PM
