Injector help
i believe you shouldnt be running anything past 550cc but even with that on the stock jdm ecu your running extremely rich and still need to pull fuel wit some sort of piggyback such as s-afc
aight man thanks, I got some injectors shopping to do. As the peggyback Im getting an APEXI S-AFC. one of my friends has one in his car and i heard they works good on the jzs too.
yea I guess, my engine is the japan spec so im on 440 injectors. but im going 550s.,so if im getting aftermarket 550 injectore is there anything particular i should look at in them or its like a plug and play thing? do i have to get something else with it to make it work
alright and Im sure im gonna get the fuel rail with the injectors as a set. does the gte uses a resistor box with their injectors or it depends on the injector you get, as in after market injectors..
The resister box is just if you want to use the stock 550s from a usdm 2jz and stock aristo ecu (i think). Otherwise just use the fic to control the flow on your aftermarkets.
atl4love
GS - 1st Gen (1993-1997)
Nov 25, 2008 06:02 PM
SlideMySC
Oct 11, 2004 09:49 AM
