As far as I know nobody makes a bolt on kit for our cars because of the distributor. If you swap in a newer model motor from a 2gen GS, then you can get a supercharger.
yea but the question is can a 2gen engine be a direct swap with no extras to make it work.
I need a new one anyway mine died any input on that department also?
Yeah xs power has a lot of tried and documented resorces. Check out the forum called clubna-t.com they specialize in ge- turbo conversions on the 2jz and have a lot of usfull info as well as write ups on the subject
why even bother swapping in another 2jzge in there? especially if you wanna turbo it.. just go buy an Aristo 2JZGTE and swap that in. only thing you need to do i think is extend the harness and a few other minor things. after thats done you'll have stock reliable twin turbo engine that you can boost up to 400whp and if you want more power in the future you can just add a bigger turbo and it can stand up to 700whp on stock internals which is alot more than what the NA 2jzge can stand.
