Help Please
Old Mar 18, 2011 | 03:43 PM
Stolen's Avatar
Stolen
Default Help Please
Well I 'm trying to do some maintenance to the GS. I'm replacing both valve cover gaskets. The only problem is I've never done this on this car before. I have the CD dealer manuel as my only guide. I took of the throttle body, no problem, now I have to take of the part of the intake as seen in picture. I'm having an issue w/ the EGR valve removal. It's attached to the piece that I need to remove. The manuel says disconnect the EGR pipe, w that giant nut, did that then it shows two small nuts at the end of that pipe. How do you get to them I see one of them, but there so much crap in the way its hard to reach. Tried a socket, w extension its like there's no room. If someone has done this before, has a trick or a tool to recommend I would be thankful. Please help need to get car done this week end, having starter flashbacks. Thanks.....
Old Mar 18, 2011 | 09:17 PM
lanthern22's Avatar
lanthern22
Try a swivel adapter or a flex head gear wrench, dont remember which of the 2 i used. have you tryd that??
Old Mar 19, 2011 | 04:15 AM
Stolen's Avatar
Stolen
Thanks, I was probably more in need of sleep, when I woke up this morn., the swivel idea popped into my head. I will head out as soon as sun rises. Also, should have the help of a CL member swinging by this morn. So, I should be back in business today.
Peter5767
RX - 1st Gen (1999-2003)
Jul 24, 2020 07:41 PM
Marklopez
Jan 20, 2015 11:24 AM
RPH74
Maintenance
Jun 28, 2004 08:18 PM
TGRich
Jun 19, 2004 12:42 PM
elvingomez
Performance
Sep 18, 2002 04:19 AM
