2jzgte vacum source issue.
Old May 1, 2010 | 07:23 AM
CHASER4LIF's Avatar
CHASER4LIF
Default 2jzgte vacum source issue.
Hey guys, I have a question to ask. I bought a gs300 the with as 2jzgte swap and notice some of the vacuum lines weren’t connected properly, for example the PCV valve port(on the valve cover, driverside), isn’t that suppose to be connected to the intake? Well they have that port which is supposed to be connected open , instead they connected it to my break master cylinder into the hose that contains vacuum on the intake where the PCV is suppose to be directly connected to., is there a vacuum source I can tee for the break master cylinder... this motor is from a 1991 aristo..
I know the picture is ****ty took it of my black berry, nevertheless it can give u guys an idea exactly on what I’m talking about.
Old May 1, 2010 | 08:42 AM
Kaiser's Avatar
Kaiser
Being that the aristo came with hydro brakes, the guys who installed it got lazy and instead of drilling a new vacuum port into the intake they used the PCV. You can correct it by taking off the intake, drilling a new port in the back of the manifold and reconnecting the PCV.
Old May 1, 2010 | 01:45 PM
vtec-this's Avatar
vtec-this
on the top of the intake manifold towards the firewall there should be a bolt sitting on top.
i used a banjo bolt and a banjo fitting and and ran a vacuum line from there to the break booster with a one way check valve in line
Old May 1, 2010 | 01:49 PM
vtec-this's Avatar
vtec-this
u can see what iam talkin about in this pic
Old May 1, 2010 | 02:19 PM
Kaiser's Avatar
Kaiser
There is no bolt on top of the manifold from Japan, that is the point. He will have to remove the manifold, drill, wash, reinstall and then use a banjo bolt.
Old May 1, 2010 | 09:47 PM
vtec-this's Avatar
vtec-this
so your saying my jdm front clip came with a us spec IM??????? no dont think so
Old May 2, 2010 | 08:40 AM
Kaiser's Avatar
Kaiser
Did I get robbed then? I can't explain why you had a fitting, but no one else does. This is not the first time I've been asked this question. Check the swap sticky, this is covered in there.
Old May 2, 2010 | 09:00 AM
CHASER4LIF's Avatar
CHASER4LIF
well i found a vacum source back of the intake, so is it safe to use that vacum? my boost
Old May 2, 2010 | 09:25 AM
Kaiser's Avatar
Kaiser
vacuum is vacuum as long as it comes off the intake and doesn't rob another source like PCV.
Old Jul 6, 2011 | 08:23 PM
Carfreak70's Avatar
Carfreak70
i know this is a hella old thread, but mine came with it aswell. i just need the banjo bolt. anyone know where i can get one?
Old Jul 14, 2011 | 02:59 AM
Turbo147's Avatar
Turbo147
yea i took the bolt and bajo fitting off my GE and took off the upper plenum and drilled and tapped for a stock fit and look.. like the lower pic
Sonic_RC
Performance
Jan 19, 2014 09:31 PM
JesLet
Mar 22, 2013 04:09 AM
dawizone
Jan 23, 2011 10:44 AM
