DS rebalancing?
Old Sep 14, 2008 | 06:17 AM
zazzn's Avatar
zazzn
Default DS rebalancing?
Hi guys,
I changed my trans a few months ago, and I stupidly didn't mark the bolts and the spots on the rubber dampner so that I knew which bolts came from which side or hole.
Anyways I took it down completely but didn't seprate it meaning i took it down as one peice....
I need to know the direction of the rubber dampners, and if the bolts are diffrent weights and the way they go in (head frist or nut first)
Basically I got a vibration at 80KM+ and it goes a way again at 150KM.
It's driving me nuts and it only started after the trans was changed.....
HELP!!
Old Sep 15, 2008 | 12:27 AM
zazzn's Avatar
zazzn
anyone?!!??
Old Sep 15, 2008 | 07:19 PM
atl4love's Avatar
atl4love
are you sure that you didn't touch the engine or engine mount??? it could be the engine mount....that my opinion...
Old Sep 15, 2008 | 10:45 PM
monkiwrnch's Avatar
monkiwrnch
the only this i can imagine in fixing it is to start switching the bolt holes on the dampner. i think theres only 4 right? and see if the vibration disappear.
Old Sep 17, 2008 | 01:06 AM
zazzn's Avatar
zazzn
positive it's not the mount didn't go near it, it feels like the whole car is vibrating and it's not RPM specific.
6 on the dampner..
Can someone take a pic of theirs so i can see how the bolt/nut is placed? Is it 3 witht he bolt going form the front and 3 form the back?
Old Sep 17, 2008 | 01:11 AM
JeffTsai's Avatar
JeffTsai
I've taken the DS on and off my car at least 7-8 times now. I never marked it nor re-lined it once I put it back on the car. I just bolted it in however it will fit. I've never had a vibration problem. The factory DS is a 2 piece and I think is balanced separately. I don't think you should have any vibration issues. Have you ruled out the transmission? Possibly the flex plate bolts or toruqe converter bolts are loose and the TC is wobbling around? Just a though. Try to rev up in neural slowly to 3-4k rpm and see if you get any wobbling. IF so...then that's your problem right there. Yes, I know my car is a 2GS but the 1GS drivetrain, engine, transmission, driveshaft, and rear diff design is very very close to the 2GS.
Old Sep 17, 2008 | 08:33 AM
zazzn's Avatar
zazzn
Hi Jeff,
Thanks for the reply, but the problem does not apear at all reving though the range, only when rolling speed is over 100KMH - 150KMH.
I was thinking the same thing as you... It shouldn't matter but some reason it makes me regret ever touching it....
The big spacer bolts go ontop of the carrier not below right?
Old Sep 17, 2008 | 01:07 PM
jmax.garage's Avatar
jmax.garage
Zazzn, check your alignment; if you have a bent torsion bar or lower control arm this will cause vibration... did you curbed the vehicle recently, lend it to a friend, or lend it to your wife or GF to go get something from the store? This could be apossiblilty. If the tranny doesn't vibrate while reving it then take into consideration your suspension... blown struts or suspension damage... just my 2 cents... good luck.
Old Sep 17, 2008 | 06:06 PM
zazzn's Avatar
zazzn
Just had the car aligned like 1 month ago! Changed 2 upper control arm/ball joints. 800$! Also had the wheels balanced and everything is super smooth.
Shocks are newer too they are tiens, evertying is smooth pass 150KPH and under 80KPH.. i mean silk!
Thanks for the help guys anyone have pics of their DS so I can refrence the bolt directions and the spacers on the carrier...
Thanks,
Old Sep 18, 2008 | 08:49 PM
twojayzee's Avatar
twojayzee
Your driveshaft is out of phase. Make sure the u-joints and the slip yoke line up. And voila
Old Sep 21, 2008 | 01:25 AM
zazzn's Avatar
zazzn
two jay please explain more i dont quite understand what you mean.
Old Sep 21, 2008 | 08:54 AM
twojayzee's Avatar
twojayzee
I know in the first post you said that the DL didnt get separated and you took it out as one piece. Are you sure it didnt get separated at any point ?
Check the bottom of this. Im trying to think of a better way to describe it.
http://jniolon.clubfte.com/driveline...nephasing.html
Old Sep 23, 2008 | 06:01 AM
zazzn's Avatar
zazzn
positive it was never seprated at any time.... could it be the telescopic part?
Old Sep 23, 2008 | 09:52 AM
2JzGs300's Avatar
2JzGs300
i didnt know that switching the direction would even make a difference
Old Sep 23, 2008 | 05:38 PM
twojayzee's Avatar
twojayzee
Certainly could be. dampner is tight, bolts tight, mounts tight, driveline tight. Can you put it on jackstands with it in drive and see a vibration ?
