Big problem--is this car junk?
Old Aug 14, 2008 | 12:33 PM
sebastian0's Avatar
sebastian0
Default Big problem--is this car junk?
'93 GS 300
This car has two small holes in the engine block, right above the exhaust manifold. The back one spits out oil when it comes up to temp. Puffing white smoke out of the exhaust.
I can't imagine any scenario where this would be anything less than a huge problem. Maybe a piston ring chunked apart and flew out through the block, and it sounds like the head gasket is probably toast as well.
The spark plugs turn black in no time at all, so it looks like it's running rich. The car runs and idles ok, a little rough, but really not too bad.
Any last-minute ideas before I get rid of this thing and take a huge hit on it, financially?
Old Aug 14, 2008 | 12:59 PM
YupImJOee's Avatar
YupImJOee
engine is gone most likey if there are holes in it.
I found a 2jz engine + tranny set for 500 out here in cali.
Old Aug 14, 2008 | 01:16 PM
sebastian0's Avatar
sebastian0
The problem is going to be labor. I don't have the tools or the know-how to do the swap myself. Wonder how much that'll run me.
Did you turbo yours in the process of swapping it?
Old Aug 14, 2008 | 01:59 PM
Kaiser's Avatar
Kaiser
It sounds like you might have damaged the waterjacket if white smoke is coming out. The spitting out oil means that you are losing oil and oil pressure. Without tearing it down you won't really know what happened. Put a fork in that motor, it's done.
Take the hit on it or put $3500 - $5000 into it and swap it to an Aristo.
ArmyofOne
Maintenance
15
Nov 23, 2015 10:54 PM
mcintosh1
Jul 31, 2015 01:28 AM
cpbehling
North Texas Lexus Club
Jul 19, 2012 07:55 AM
dundfaukus
15
May 31, 2007 12:59 PM
crazyxbobo
Apr 22, 2002 12:41 PM
