funky air
Old Dec 24, 2007 | 09:10 AM
novak82's Avatar
novak82
Default funky air
ok guuys i picked yet another!! first gen..i got a third so i could have a canidate for SPracings sequential twin turbo kit ..but anyway the thing is when i turn the air on or heat or anything ..mannnnn tha **** reaks really really bad ...im thinkin its mildew because i checked the space for a cabin filter and of course there wasnt one ...but the leaves that were in there were damp and so was the surface inside ..and when i smelled my hand it had that same flippin smell..any suggestion on solving this problem
Old Dec 24, 2007 | 09:23 AM
JeffTsai's Avatar
JeffTsai
lol I just had to laugh when I read your post.
First and foremost...clean out as much of that garbage out as you can. Get a rag and jam your hand up into the filter area. Wipe it around as best as you can. Clean out all the leaves and crap or whatever is in there. Afterwards, drive with the heater at full temp and and full blast. Just crack the windows open if you get too hot. Basically you're evaporating the water and killing the bacteria with the heat. Do that for a few days to see if the problem goes away. That's how I got rid of the gross air smell on my last car. I've also recommended this to a few friends and it's worked out as well.
Just make sure there isn't a dead rat/bird/squirrel/rabbit/etc or something in your air vents. No amount of hot air will get that smell out until you actually remove the carcass lol
Old Dec 24, 2007 | 09:49 AM
novak82's Avatar
novak82
lmao at tha carcus lol ..but thanks man im goin to go do that right now
Old Dec 24, 2007 | 10:09 AM
Kaiser's Avatar
Kaiser
Check the filter behind the glove box, then spray Lysol into the air vents just under the windshield while the air is on HIGH. This should kill the bacteria in your system.
Old Dec 24, 2007 | 10:33 AM
novak82's Avatar
novak82
oo yea another thing wit this car that i havent had wit my other 2 ..omn tha dash theres lil yellow car looks like its doing a burnout lol...wat tha hell those that mean
19psi's Avatar
19psi
you can remove the cowl and vaccuum everything out. then get some a/c deodorizer from a good parts store and follow the instructions on the can.
Old Dec 25, 2007 | 11:58 PM
Jmai22's Avatar
Jmai22
Ok, your car will smell during the winter months when you use AC because it is not used enough. Just make sure anytime you use AC, and 5-10 minutes before your destination hit the AC button so the light goes off. This will blow just regular air through your vents which will remove any condensation that was built up while AC is on.
gstreee
Jan 12, 2014 07:55 PM
rza8gamma
Feb 12, 2013 09:18 AM
over40driv
Jun 11, 2009 03:00 PM
kidluvsole
Jun 24, 2008 01:59 PM
SC300Es
Maintenance
May 16, 2003 04:08 PM
